Activity › Forums › Apple Final Cut Pro Legacy › lower third titles – adjusting space between 1st and 2nd line
Posted by Ira Liss on January 2, 2009 at 6:32 pmHi,
I’m using FCP’s lower third function, generating text to identify a talking head.
Text is on two lines.
1st line is name of on-camera person
2nd line is titleDo you know of a way I can modify the space
between the first and second line?(Talking in typography terms, this space is often called “leading.”)
It seems the default line spacing is more open than I’d like.
As a workaround, I’m thinking of using FCP’s text function that is just “text” and
not “lower 1/3s.” I’ve seen that “text” allows more control over leading.And then I would position the text to fit in the lower third.
Anyone know how to adjust the leading and
still stay in FCB’s lower 1/3 function?I appreciate your help,
– IraAndreas Kiel replied 17 years, 8 months ago 8 Members · 13 Replies -
David Bogie
January 2, 2009 at 7:11 pmUse LiveType and crate a separate text item for each line so they are individually adjustable. Although your reference to real typography suggests you won’t enjoy using LT either, it has no kerning at all.
The Boris text tool (Outline Text) you have in FCP are far more complex but infinitely more adjustable.
bogiesan
Ira Liss
January 2, 2009 at 7:15 pmHi David,
Thank you for your quick and helpful response.
Is LiveType a feature within Final Cut Pro
or an add on or separate program?
How do I find or access it?Thanks again,
– Ira -
Victor Perez
January 2, 2009 at 7:47 pmLiveType is located in your applications folder. If you have not previously used LiveType and are just adding simple text for supers without fancy effects it might be easier to stack two layers of “Outline Text” or “Text” from Final Cut and then move each layer up or down to your liking in the canvas. LiveType is great, so get used to it but, it can be a bit complicated if you have not used it before. Things like Format, Aspect, Size, Background, etc can change the look (ratio) of your titles when rendered out or used as an .ipr file.
Depending on the project we usually stack 2 Text Files for simple titles and use LiveType for GFX text.
Other projects call for individual LiveType titles with effects.good luck,
Victor
David Roth weiss
January 2, 2009 at 7:55 pmDon’t ever use the FC text tool, always use Boris 3D. After creating two lines, highlight the lower one and slide “Style Baseline” at will to move that line up or down independently.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Ira Liss
January 2, 2009 at 8:07 pmHi David,
Because I don’t yet own Boris 3D,
I’m curious as to why you advise against FCP’s text function.It’s true I am fairly new to using FCP.
So far, its text seems acceptable and workable.For the project I’m working on, text
does not need any FX, just static, straight
forward with drop shadow, supered next
to different on-camera talking heads.I do appreciate your taking the
time to share your thoughts.Thanks,
– Ira
storyboards
and graphics -
Tom Wolsky
January 2, 2009 at 8:23 pmYou do own Boris Title 3D. It’s in the Boris submenu of the Generators. It’s a vector based, full featured titling tool. All the text tools are really legacy tools and largely redundant. They really should no longer to used except for the simplest titling for placeholders and such.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
David Roth weiss
January 2, 2009 at 8:25 pm[Ira Liss] “Because I don’t yet own Boris 3D, “
Sure you do, it comes as part of FCS. If you click on the film frame with the A on it at the lower right under the viewer, you’ll see Boris listed. In there you’ll see Title 3D. Learn it, it’s the text tool almost everyone uses, because the FC text tool is simply inferior.
David Roth Weiss
Director/Editor
Victor Perez
January 2, 2009 at 8:40 pmThanks David,
We have another series entering the edit suites within a month. I will be starting on a basic template and will incorporate the use of Boris Title then.
Victor
Ira Liss
January 2, 2009 at 8:43 pmThank you, all!
Yes, I see I do have Boris as part
of FCP.I’ll start using it as I want my skills and
tools to be up-to-par with the industry.Thank you again for sharing
your time and wisdom.Regards,
– Ira
storyboards
and graphics -
Tom Matthies
January 3, 2009 at 3:50 pmI have to comment on David’s post above. Live Type does indeed have the ability to kern letters separately or as a group. Any letter can be adjusted to any degree in relation to the other letters. Simply highlight the letter(s) and using the Cmd “arrow” keys, it can be moved anywhere in relation to the other letters on the baseline. Very “Chyron-like” actually.
Tom
