Activity Forums Adobe After Effects Lower third Technique/Effect
  • John Cuevas
    August 23, 2012 at 1:18 am
    Many methods to creating an effect like this, but the way I would do it would be to use a track matte. So I would create my background and animate it’s position, then duplicate the layer. Now create your text an animate that from offscreen to it’s final position.
    Now place the text underneath the duplicate and change it’s track matte to alpha matte.
    Here’s a quick project demonstrating the technique: 4577_lowerthirdanimation.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Mark
    August 23, 2012 at 5:57 am
    I understand how to do all of that, but i needed to know when the lower third slides onto screen I want to know how they keep the lower third sliding in with no picture of the world until it shows at the end were the 7 news logo is, because i have one white bar sliding in just like in the clip and i have added the world feature as a separate layer when i put the slide effect in, the world shows before it gets to the end, so basically its sliding with the white lower third but i want world being shown at the end just like the clip.
    Sorry mate this is a hard one to explain. Hope made sense
    https://www.youtube.com/watch?v=Xdek0xhUDYs&feature=plcp (Stop clip at 10 sec) picture showing
  • Tudor “ted” jelescu
    August 23, 2012 at 7:10 am
    To me it looks like it’s just a matter of animating the elements from left to right. As far as the globe image in the bar, you can just precompose the image over the white bar and animate a quick disolve in using the opacity timing it to the moment where the bar ends it’s animation.
    Just as a tip- most animations you see on news shows are built using simple techniques like disolves and position change.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • John Mark
    August 23, 2012 at 9:58 am
    Thank you all for your help, have a look of what I have tried to accomplish.
    https://f1.creativecow.net/4578/4578?uploaded=file
  • John Mark
    August 23, 2012 at 10:03 am
    If any one could make it more like the one in the clip and fix it up that will be much appreciated and send me the download of it.
