Activity Forums Adobe After Effects Lower Third Rendering
  • Lower Third Rendering
    Posted by Toby Rocke on July 13, 2008 at 3:03 pm
    Hi all!
    I actually have a sensible question for you.
    I have been asked to produce some lower third straps for a new video podcast.
    I can get the graphics to do exactly what I want, but how do I go about rendering these out to retain the alpha channel so that they can then be imported into FCP?
    I’ve tried a few methods. The most success I had was with a PNG sequence, but when they imported each one sat for about 2 seconds and did not look good.
    This may not help, but I’m not the one using FCP and I am unfamiliar with it.
    “Outside of a dog, a book is man’s best friend. Inside of a dog, it’s too dark to read”
    Toby Rocke replied 18 years, 1 month ago 3 Members · 3 Replies
  • Grant Swanson
    July 13, 2008 at 5:38 pm
    Hi Toby,
    After you add the composition to the render queue, in the Output Module Settings, set the channel to RGB+Alpha. Depth should now have a + symbol next to it. For the colors just choose pre-multiplied or straight depending on your case.
    When you render out the alpha channel will be included.
    Hope this helps!
    Grant Swanson
    Visual Effects Supervisor
    Video Apex – Minneapolis, MN
    videoapex.blogspot.com
  • Chris Wright
    July 13, 2008 at 5:57 pm
    flash only supports premultiplied, just in case.
  • Toby Rocke
    July 14, 2008 at 5:22 pm
    Thanks guys, you have been most helpful.
