Activity Forums Apple Final Cut Pro Legacy Lower Third Opacity in Final Cut Pro 6
  • Lower Third Opacity in Final Cut Pro 6
    Posted by Brad Mitchell on September 24, 2011 at 10:06 am
    I am trying to add Lower Third text to a clip but the key frames I have added in Opacity to fade text in and out doesn’t work. I’ve placed the text above the video track but the key frames aren’t recognized. The text just snaps on and off for the duration of the clip. I’ve gone so far as to uninstall Final Cut and reinstall it. No change. Any help would be great.
    Brad Mitchell replied 14 years, 11 months ago 2 Members · 2 Replies
  • Chris Tompkins
    September 24, 2011 at 10:38 pm
    Did you try just apply a dissolve on and off?
    Did you double click the file and create the keyframes in the motion tab for opacity?
    Chris Tompkins
    Video Atlanta LLC
  • Brad Mitchell
    September 24, 2011 at 11:00 pm
    I’m trying to get the lower title to fade in after the upper title. I’m using the opacity settings in the Motion tab to fade in the upper title. The opacity key frames in the control tab for the lower title don’t respond. Not sure if this is the correct wat to go about it but it has worked in the past. Thanks for responding.
