Activity Forums Adobe After Effects Lower Third General Question
  • Lower Third General Question
    Posted by Nate Hanson on February 22, 2008 at 3:57 pm
    When designing a “lower third” graphic, do you professionals out there typically create it at a higher resolution than you need, and then scale it down to fit the video?
    I created a comp with the NTSC DV settings, and just designed the graphic at the bottom of the screen. I’m just wondering if that was the “proper” way to handle it, or if I should have created a comp that was the size of the graphic or something like that.
    Thanks for any input!
    Nate
    Darren Edwards replied 18 years, 7 months ago 3 Members · 2 Replies
  • Steve Roberts
    February 22, 2008 at 5:04 pm
    [Nate Hanson] “When designing a “lower third” graphic, do you professionals out there typically create it at a higher resolution than you need, and then scale it down to fit the video?”
    Nope. Why would we create it at a higher resolution?
  • Darren Edwards
    February 23, 2008 at 4:41 pm
    Presupposedly you would create a lower-third aston
    at a higher res than required to future-proof it
    for an expected jump to a HD workflow?
    Always remember to frame your astons for 14:9
    nowadays, not 16:9. Here’s a guide.
    https://www.itfc.com/assets/safeareas.pdf
    Darren.
    x-gf.com
