Activity › Forums › Adobe After Effects › Lower Third Effect
Lower Third Effect
Posted by John Mark on August 6, 2012 at 10:06 pmI was just wondering if a could get a effect the way the lower third enters the clip on screen in the link
watch?v=r_IYXn54PNU
John Cuevas replied 14 years, 1 month ago 2 Members · 4 Replies -
John Cuevas
August 7, 2012 at 12:46 amYou can easily accomplish this with the Transition -> Card Wipe. Create your lower third, bkg & text and precomp it. Now apply Card Wipe to your lower third. First set the “Back Layer” to “None” You will have decide how many “Rows” you need depending on the look you are trying to achieve. Set the “Columns” to 1. Change the Flip order to Bottom to “Bottom to Top”. Now just keyframe the transition completion from 100% to 0%.
Here’s an example project. 4501_lowerthirdwipe.aep.zip
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
John Cuevas
August 9, 2012 at 2:41 amOnly needed to thank me once…but glad I could help.
