Activity Forums Apple Final Cut Pro Legacy Lower Third Changes Hue
  • Lower Third Changes Hue
    Posted by David Bark on December 6, 2013 at 11:00 pm
    I’ve got a video with a series of talking heads, and each has a lower third graphic introducing them. Each graphic is a solid gray matte, slightly transparent, cropped top and bottom and keyframe cropped to slide on and off the screen. Two layers of simple text fade in and out on top of the matte. The speakers are against a white backdrop, and every time the lower third appears the hue (on the backdrop) shifts from off-white to a slight blue. I do not see this in the timeline, only after rendering an H.264 1280×720 .mov. Any ideas what might be going on?
    David Bark
    Lightshine Productions
    David Bark replied 12 years, 9 months ago 2 Members · 2 Replies
  • Mark Suszko
    December 7, 2013 at 6:09 am
    Tried playing with the opacity settings and blend modes?
  • David Bark
    December 10, 2013 at 4:29 pm
    Thanks guys. It seems like Sending through Compressor rather than Quicktime Conversion did the trick.
    David Bark
