Activity Forums Adobe After Effects Lower layers appearing over top layer
  • Lower layers appearing over top layer
    Posted by Ahill on August 29, 2005 at 3:11 pm
    Using 6.0. Some, not all lower layers appearing over top layer. (Opacity set to 100) Any suggestions?
    Alex
    Ahill replied 21 years ago 4 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    August 29, 2005 at 3:18 pm
    Are the layers 3D?
    Dan
  • Ahill
    August 29, 2005 at 3:25 pm
    Also, Problem seems to occur only when using the 3d layer controls.
  • Miller
    August 29, 2005 at 4:01 pm
    Yes, 3D layers rely on Z position for location. (in front of…in back of.)
  • Ahill
    August 29, 2005 at 5:06 pm
    I understand, however why would this only be the case with some, not all, of the layers at the same Z position? In other words if I set the Z position, then drag the image left or right only some of the lower layers (all at same Z) appear over top of the image.
  • Joshua Ferg
    August 29, 2005 at 5:17 pm
    Are you running open GL?
  • Ahill
    August 29, 2005 at 5:40 pm
    No open GL
  • Ahill
    August 30, 2005 at 9:33 pm
    Thanks for all of the feedback, had to just use 2D space. (Looked just as good as 3D anyway)
    Alex
