Activity Forums Adobe After Effects Lower Field question-video & gfxs
  • Lower Field question-video & gfxs
    Posted by Jaime Lackner on March 2, 2008 at 1:26 pm
    I apologize in advance since I have searched this question in previous dates and have found useful answers, but I really just want to make sure so I can supply the editor with the correct animations.
    He is working on an Avid. I’m working in NTSC D1 Widescreen (1:2)and rendering it out using the Avid Meridien Compressed
    When I import the footage, it tells me that it is lower field first. SO should I render it back out as Lower Fireld first?
    What if I pre-render it? Pre-render lower field, than lower field again when final render?
    For graphics, with alpha, or straigth. Does it matter if I just use no field? Or should I stick with lower?
    Thanks so much!
    Jaime Lackner replied 18 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
