Activity › Forums › Adobe After Effects › Lower Bitrate gives me same file size
  • Lower Bitrate gives me same file size
    Posted by Gustavo Richieri on July 5, 2021 at 12:16 pm
    Just some context. I need to render some videos to use them as rich media for digital displays. Usually I just render them with low bit rates (both target and maximum) and it always seemed to work. Now I’m setting both target and max on media encoder at 2 and it will still give me the same file size as if it was set to 10.
    Is that a bug or is there something I’m missing?
    Exporting video to h.264 format, by the way.
    Thank you
    Graham Quince replied 5 years, 2 months ago 2 Members · 1 Reply
  • Graham Quince
    July 10, 2021 at 8:56 am
    I’ve found this – especially noticeable with animated gifs, where often you have a size limit.
    I think AME always renders the best option for lossless (speculating here) and often lossless can be below the target value.
