Activity › Forums › Apple Final Cut Pro Legacy › Lower Bass
Lower Bass
Posted by Bullpup on November 16, 2005 at 4:36 pmIs there a filter in FCP that lowers the bass?
Bullpup replied 20 years, 10 months ago 3 Members · 4 Replies -
Bouncing Account needs new email address
November 16, 2005 at 6:10 pm“3-Band EQ” will increase the LEVEL of any frequency that is already recorded.
If you want to “synthesize” lower bass (create it an octave lower that is recorded) that would be an outside audio program with than kind of filter.
Jimr
November 16, 2005 at 9:12 pmJust apply a 3 band filter to the track.
Then under filters pick a lower Freq. 50hz-100-200 Etc. which might be close to the bass you want lowered.
then apply a negative # -1–to -10 to lower that Freq. as much as needed to your liking.
trial and error will get you what you want.JimR013
