Activity Forums Adobe Audition Low Vocal Volume
  • Low Vocal Volume
    Posted by Bruce Orkofsky on August 19, 2005 at 12:03 am
    I am a complete newby with Audition. I have some footage that was shot at my son’s wedding a few weeks ago. I am going to be doing th editing and when we watched some of the footage it turns out that where the videographer interviewed guests at the tables that ther voices were drowned out by the music coming over the speakers even though the people were only a few feet away from the camera. He said he had a very good mike attached to the camera, not a separate handheld or lapel mike but the voices are so low it is very hard to hear them.. I have seen other replies to similar problems by Willie Toth and would appreciate any help. I need to be able to loweer the volume on the music and raise it on the people speaking.
    Please help as this is so very important for me to be able to fix.
    Thank you,
    Bruce
    Thank you,
    Bruce
    Bruce Orkofsky replied 21 years, 1 month ago 2 Members · 11 Replies
  • 11 Replies
  • Willie Toth
    August 19, 2005 at 12:24 am
    Bruce,
    Could you E-mail me a about a minute clip … There isn’t a lot you can do but let me have a crack at it and if I am successful I will give you direction … E-mail it to loganonestudio@aol.com
  • Bruce Orkofsky
    August 19, 2005 at 1:35 am
    How do I e-mail a clip? Should I bring in the part with the problem into Audition and save it as a certain type of file?
  • Willie Toth
    August 19, 2005 at 2:32 am
    Bruce,
    Yes, bring it into audition on the session or multi track side … This is simply done by going to the insert tab at the top left of the screen INSERT > AUDIO FROM VIDEO … Once the clip is in take and highlight about a minute or so of the troubled area now go to EDIT > MIXDOW TO FILE > SELECTED AUDIO CLIPS … This will mixdown just the highlighted area and will place it onto the edit side of the program … Next go to FILE > SAVE AS once you get the screen up choose a place where you can locate it and save it as an MP3 PRO file … Now close Audition it is going to ask you if you want to save the session, just say no to everything … Next open your E-mail and attach the MP3 file ……….. WILLIE
  • Bruce Orkofsky
    August 19, 2005 at 2:53 am
    Willie,
    OK, that sounds pretty straight forward. It is a bit late to do it tonight as I haven’t captured it to my computer yet, I will try Friday night or Sunday as I have to leave early on Saturday for the day.
    I use Edius 3.3 as my NLE program. Should I use that to capture some of the footage or can I just capture it straight into Audition. If I use Edius I think it will be an AVI file. What do you suggest?
    Thank you so much for your help.
    Bruce
  • Willie Toth
    August 19, 2005 at 12:24 pm
    Bruce,
    No, you need to capture first then import to Audition ………. WILLIE
  • Bruce Orkofsky
    August 19, 2005 at 12:38 pm
    Hi Willie,
    OK no problem. Usually when I capture with Edius it saves it in Windows Media format at first. Will Audition read it ok that way?
    Also I am not at home now so I can’t check but when I played around with another clip last night I got a prompt about saving the file first, I forget exactly what it said. This was before I was going to do a Save As. Do you know what this is and if I should choose Yes or No?
    Bruce
  • Willie Toth
    August 19, 2005 at 2:08 pm
    Bruce,
    Yes, it saves as an AVI … Just say no to everything right now ……. WILLIE
  • Bruce Orkofsky
    August 19, 2005 at 3:12 pm
    OK, Great. Thanks Willie I really appreciate your help. I really need to salvage that footage as it cannot be shot again due to the fact that it was at our son’s wedding reception. I’ll try to capture some of that footage tonight and send you an audio clip. I guess that I can do as you have suggested to other people with audio problems and grab just the music and then filter it out for these clips. Can you do that but just lower the music volume so it is not completely gone?
    Bruce
  • Willie Toth
    August 19, 2005 at 3:23 pm
    Bruce,
    Wish it was that simple … Send the clip and we can go from there …. WILLIE
  • Bruce Orkofsky
    August 19, 2005 at 4:59 pm
    OK Willie will do.
    Thank you,
    Bruce
