Activity Forums Adobe Premiere Pro Low quality still image renders. What are we doing wrong?…
  • Low quality still image renders. What are we doing wrong?…
    Posted by Dave Draper on March 9, 2017 at 8:32 pm
    We have a video with still image overlays on it (company logos, etc), but every time we export out of Premiere — using the GoPro Cineform YUV 10-bit codec — the images in the video appear low in quality with fuzzy edges (like a smaller image that has been upscaled), when in reality, they are higher in resolution than the source video.
    If we export using either the GoPro CineForm RGB 12-bit with alpha or Maximum Bit Depth variation, the images in the video appear high in quality, with crisp edges — as they should — but all video transitions in the edit are ignored.
    Clearly we’re doing something wrong somewhere, but does anyone know where?
    Ole Kristiansen replied 9 years, 6 months ago 6 Members · 19 Replies
  • 19 Replies
  • David Roth weiss
    March 9, 2017 at 9:33 pm
    Post a screen shot of your sequence settings please.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Dave Draper
    March 9, 2017 at 9:46 pm
  • Andy Patterson
    March 10, 2017 at 12:25 am
    What happens if you render using the CPU instead of the GPU?
  • Jeff Pulera
    March 10, 2017 at 2:28 pm
    Hi Dave,
    You said the overlay graphics are higher resolution than the video, which means Premiere has to be doing some scaling. Take that out of the equation. In Photoshop, make the graphics all 1920×1080. Bet that helps. Even if just a corner bug, put it in a 1920×1080 frame with transparency.
    Jeff Pulera
    Safe Harbor Computers
  • David Roth weiss
    March 10, 2017 at 2:40 pm
    Change your sequence settings… First change Editing Mode to DNXHD, then change Preview File Fornat to one if the DNX options. The defaults, i.e. DSLR and MPEG I-frame are shredding your still image quality.
    David Roth Weiss
    Los Angeles
  • Dave Draper
    March 11, 2017 at 7:49 pm
    David. Many thanks for your suggestion. Unfortunately, this hasn’t made a difference to the image quality…
  • Dave Draper
    Still the same…
  • Dave Draper
    March 11, 2017 at 7:56 pm
    Tried this as well, but hasn’t made a difference.
    I swear I encountered this problem a few years back, but managed to solve it somehow. Just can’t remember how. Very frustrating.
    All I know is, the only way I can (currently) get the video to look the way it should look, is by exporting at 12 bit with the alpha channel.
  • Korin Unka
    March 14, 2017 at 7:45 am
    Maybe delete your “common” folder under appdata>adobe … could be caching issue
  • Dave Draper
    March 14, 2017 at 3:58 pm
    Deleted the cache, and hasn’t made any difference, unfortunately…
