Activity Forums Apple Final Cut Pro Legacy Low quality results when exporting DV PAL clip?
  • Low quality results when exporting DV PAL clip?
    Posted by Daniel Grixti on July 2, 2010 at 4:28 pm
    Hi there,
    I am trying to export my timeline and burn the exported file with DVDSP. It is a very long timeline (3 hours) so I plan to export it in sections and spread it over a 2-3 DVDs. Or possibly try a duel layer DVD.
    The problem is, when I export a small test section of the clip, the resulting .mov file i very low quality.
    I have been going file > export > Quicktime Movie… > Choose DVD PAL Anamorphic (My project is HD but I will only be exporting a normal DVD). I have tried reference and self contained. The resulting .mov I get from this is very low quality!
    I have also used the same process but exported an uncompressed .mov as a benchmark. The quality here is excellent but the file size in enormous, around 500mb for a 4 seconds.
    The best compression I have found was PRORES HQ but I have been advised not to use this for the DVD.
    Every tutorial I have found it just says simply choose your setting, DV PAL or NTFS, export the Quicktime Movie and then import that into DVDSP. I don’t understand because the .mov from this method seems so much lower quality then the uncompressed or PRORES.
    Am I just totally missing something here or doing something wrong. I have been trawling the forums and exporting countless amounts of test clips but just cant seem to crack this one.
    Any help would be much appreciated! I need to deliver this DVD tomorrow! AARGGHH.
    Dan
    Zane Barker replied 16 years, 2 months ago 2 Members · 1 Reply
  • Zane Barker
    July 2, 2010 at 7:16 pm
    Don’t export using QuickTime conversion. Export using current setting and then take that file into compressor.
    Hindsight is always 1080p
