Activity Forums Maxon Cinema 4D Low poly landscape with shaded wire frame look
  • Brian Jones
    September 29, 2011 at 11:20 pm
    sketch and toon, use it for the poly edges but in the Sketch Shading settings to Off for the Background and Object
  • Robyn Rhodes
    September 30, 2011 at 2:48 pm
    Hi Brian. Not to familiar with the Sketch and Toon tool. Could you be more specific or upload a project?
    I’m only half the thing I say I am, the other half are me.
  • Brian Jones
    October 1, 2011 at 6:41 pm
    Sketch and Toon is pretty deep and it can be done more than one way. For that scene you need S&T on only one object but it is on for the whole scene by default and you don’t want the S&T background or Object shading. The first step is to turn the Background and Object shading off in the S&T Render Settings/Shading tab. Then either you can put a Sketch Style tag which turns off the the S&T lines for the robot etc or Turn off all lines in the S&T Render Settings and use a Sketch Style Tag to turn them on only for the landscape. Here’s an example of that 3013_stexample.c4d.zip
