Activity Forums VEGAS Pro Low Memory error with no video clip loaded.
  • Low Memory error with no video clip loaded.
    Posted by Omer Aydin on April 29, 2011 at 12:46 pm
    Hello,
    Could you please test this on your Vegas 9?
    – Open a new project and put anything on timeline. (any still from Media Generator would be ok)
    – Render it as MP4 using MainConcept AVC/AAC encoder.
    – Choose Apple IPod 320×240 template and open Custom panel.
    – Set Frame Rate to 15,
    – Set Constant Bit Rate to 192.000
    Vegas Pro 9 won’t render it due to “low memory” on my system while Vegas 6 does.
    Do you also get a low memory error?
    Brian Luce replied 15 years, 4 months ago 4 Members · 5 Replies
  • Fabio Mereghetti
    April 30, 2011 at 5:45 pm
    Check if one of the two temp folders you have somewhere in the settings is on a full (or almost) HDD.
    It was some time ago I had the same issue and for me the problem was there.
  • Omer Aydin
    April 30, 2011 at 9:55 pm
    My system has 4 HDs and the drive with lowest free space has ~6 GB free.
    I assume it’s an issue regarding my system since no one replied saying they had a low memory error.
    ..or I’m asking the wrong question. May be I should ask `Anyone NOT seeing an error doing the test above?` to be sure that people actually test it.
  • Mike Kujbida
    May 1, 2011 at 11:07 am
    I can confirm that I get the error in Pro 9.
    It works just fine in Pro7, 8 and 10 so Sony broke something in Pro 9 but fixed it again in Pro 10.
  • Omer Aydin
    May 1, 2011 at 2:23 pm
    Thanks Mike.
  • Brian Luce
    May 1, 2011 at 9:43 pm
    Vegas 9 used to drive me crazy with this error. Once I went to v.10, problem went away completely.
