Activity Forums VEGAS Pro Low Memory Error
  • Low Memory Error
    Posted by Matthew Engelson on July 14, 2012 at 10:53 pm
    Hi there,
    I was trying to change the resolution of one of my projects from 720×480 to 1920×1080, but the rendering stops part-way through with a message that says:
    “The system is low on memory. You may be able to reduce memory usage by closing other applications.”
    The only thing I have actively running is Vegas and according to the Task Manager, my physical memory is between 27 and 32 percent.
    Is there another reason for this error?
    Thanks for your help!
    Stephen Mann replied 14 years, 2 months ago 2 Members · 1 Reply
