Activity › Forums › VEGAS Pro › low ligth noise
  • Laszlo Kovacs
    February 23, 2008 at 7:15 pm
    First, it surely needs some cutting.
    Apply some brightness/contrast filter, I think that will be enough.
    Maybe, some color corretcion after BC, but that will you see if it is required.
    Hope I could help
    Regards
    K.L.
  • Odd Magne nilsen
    February 24, 2008 at 7:25 am
    Thanks a lot for your answer.
    Good to know where to start.
    Vegas Pro looks to give me almost unlimited opportunities.
    It’s great to have the option to correct the scene while playing previuw.
    odd magne nilsen
    newbee
  • Theo Van laar
    February 24, 2008 at 11:06 am
    Odd,
    To obtain the best results, never use the BRIGHTNESS AND CONTRAST FILTER, since this will treat all your pixels in the same way. First of all, start using your Histogram in the VIDEOSCOPES to analyse your footage. Then optimize the use of the colour spectrum using the LEVELS effect. Set the whitebalance and the ‘black’ with the COLOR CORRECTOR en set the brightness with the COLOR CURVES EFFECT. The latter has the advance over the BRIGHTNESS AND CONTRAST FILTER that you can adjust dark and light pixels seperately.
    Theo
  • Odd Magne nilsen
    March 28, 2008 at 7:54 am
    Hi Theo van Laar,
    I’m very pleased with the result of your advises. So pleased that I, after a trial of Vegas Pro 8, bougth it.
    odd magne
    odd magne nilsen
    newbie
