Activity Forums VEGAS Pro Low light problem solved
  • Low light problem solved
    Posted by Richard Milner on August 9, 2011 at 2:22 am
    I found that the ir security camera’s will pull enough light in so I can get a shot into the audience. It isn’t as clear as I want, but it is extremely cheap.
    If I get another better camera that does better and possibly a zoom/focus from remote them , this will do.
    I will post footage when I finish rendering the other video’s.
    Thanks you guys for all your help!
    Blessings!
    Richard
    Paul Goelz replied 15 years, 1 month ago 2 Members · 1 Reply
  • Paul Goelz
    August 10, 2011 at 4:19 pm
    If the camera you are using is really imagin in the near I/R, look closely at the images to make sure that they look OK. People and clothing can look odd when imaged in near I/R. For clothing, “odd” can range anywhere from the wrong grey shade to semi-transparent…. probably not a good thing for your application? 😉
    Paul
    Paul Goelz
    Rochester Hills, MI USA
    paul at pgoelz dot com
