Activity Forums Audio Low level hiss in Sony URX-P2 Receiver
  • Low level hiss in Sony URX-P2 Receiver
    Posted by Robert Riggs on February 13, 2012 at 4:00 am
    I am picking up a low level hiss from my Sony URX-P2 receiver. I have tried different channels but the problem continues. Please make any suggestions.
    Steve K-mann replied 12 years, 5 months ago 3 Members · 6 Replies
  • Ty Ford
    February 13, 2012 at 1:43 pm
    Hello Robert and welcome to the Cow Audio Forum.
    Hiss is hard to track down. Compared to what?
    First does the receiver output mic level? Is your camera set to mic level?
    If you’re using third-party mics and they aren’t terminated properly, there will be hiss or distortion.
    Are you used to larger diameter mics? Lave are noisier.
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
  • Robert Riggs
    February 13, 2012 at 4:20 pm
    Ty, thanks for the response. I am using a sony transmitter with lav and a mic cube that came with the package. Is the URX-P2 fragile and prone to having a crystal knocked loose if you drop it?
    I get the low level his on the lav and a rode shotgun mic. thanks
  • Ty Ford
    February 13, 2012 at 4:50 pm
    Robert,
    I don’t have hands-on experience with that system. Perhaps someone else here may.
    Dropping is usually not good.
    Again, sure you’re not feeding a mic level into a line level input and having to crank it way up?
    That’d cause hiss.
    Regards,
    Ty Ford
  • Steve K-mann
    April 23, 2014 at 7:31 pm
    Did you ever track down the source of your hiss?
    I’m having this problem:
    https://forums.creativecow.net/readpost/142/881266
  • Robert Riggs
    April 23, 2014 at 10:08 pm
    There was a problem in the receiver. I returned the unit which was still under warranty to Sony. They replaced it with a brand new one.
  • Steve K-mann
    April 24, 2014 at 12:14 am
