Activity › Forums › Adobe After Effects › Low frames per sec look ae?
Posted by Jack Sewell on December 13, 2012 at 9:17 amHi all!
Is there an easy way to achieve a 12 frames per second / stuttery look in AE?
JackTodd Kopriva replied 13 years, 9 months ago 3 Members · 2 Replies -
John Cuevas
December 13, 2012 at 2:26 pmEffects > Time > Posterize Time works pretty good
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Todd Kopriva
December 13, 2012 at 9:29 pmA better way is to nest the composition in a composition with a low frame rate. The benefit over using the Posterize effect is that the nesting case only needs to evaluate the smaller number of frames, whereas the Posterize case needs to evaluate all of the frames.
After Effects team blog
