Activity › Forums › DaVinci Resolve › low cost / DIY / beginner calibration solution for Resolve/Panny
Laco Gaal replied 14 years, 10 months ago 5 Members · 12 Replies
Jason Myres
November 14, 2011 at 6:21 pm[Laco Gaal] “But I always heard that plasmas are drifting, and need to be calibrated often, what’s the resolution for that?”
By buying what you can afford, learning it inside and out, and understanding that while you may not achieve perfection, you will be able to make/ keep your monitor more accurate than it was out of the box.
Definitely hire a professional calibrator to help you determine an initial profile, but if you take the time to learn how to calibrate it yourself, it will be an invaluable skill for you as a colorist. No time to start like the present.
JM
