Activity › Forums › Broadcasting › LOW COST- A/V Routing Distribution System- Solution HELP
  • LOW COST- A/V Routing Distribution System- Solution HELP
    Posted by The Buttercow on February 13, 2006 at 1:04 am
    I need to collect audio/video from 8 rooms and send it to a central location and reroute it to as many as 8 or ten other rooms.
    I have done this in the past by taking an RF signal from a 1/2
    Mike Cohen replied 20 years, 7 months ago 2 Members · 1 Reply
  • Mike Cohen
    February 15, 2006 at 4:19 pm
    look into a 10×10 router so you can send any signal anywhere without any manual patching. You may be able to get a system with extra serial control panels which you could have at each gen and rec station. if each signal is going to more than one destination besides the router, such as a local monitor at the source, or to a video switcher or recorder, put a DA at the source end.
    I would avoid taking the video signal out of the dvd recorder, as you could get the silly on-screen display from the dvd recorder recorded onto your other recordings. Distribute the source before the recorders and long cable runs, which can save extraneous long cable runs. And diagram this out in Excel before you even buy any gear, to make sure it is logical for maintenance also.
    Mike
