Activity › Forums › Broadcasting › Low Audio Recording Levels in Panasonic AG-DVC30
  • Low Audio Recording Levels in Panasonic AG-DVC30
    Posted by Jeremygb on April 20, 2006 at 7:19 pm
    About a year ago I bought a Panasonic AG-DVC30 camcorder. The image is great, but the sound level stinks.
    Recently I made a semi “scientific” study of the sound levels. I set up a standard color bars & tone in Premiere, positioned the camera about 10 feet from the speakers and then tried various mic settings. I imported them into Premiere and looked at them with its audio meter. ‘Course, this does not relate to any objective scale, but the relative levels are perhaps significant. And I did set the loudness of the tone so that it was roughly equivalent to humans talking.
    When I use the built-in mic and the default settings (i.e., AGC), I get a reading of
    -30 dB
    Which seems very low to my ear. When I attach an external (shotgun) mic and connect the cable to the “mic” input, I get the same thing:
    -30dB
    However, if I shoot the same thing using a modest, consumer-grade Canon camcorder in exactly the same location, I get:
    -12 dB
    Which sounds “normal” to my ear.
    Next, I set the AG-DVC30 to manual level setting (which is a pain because you have to go through 2 or 3 menu levels). This way I could bump the record level a notch or two and achieve -18 dB or higher.
    My main question is: Is this camera defective?
    Thanks for the advice.
    Jeremy
    Jeremygb replied 20 years, 5 months ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    April 20, 2006 at 9:19 pm
    Don’t know this camcorder, but it sounds like you might have a MIC ATTENUATION setting turned on.
    Check the menus and slide-switches for this.
    That could account for 10 to 20 dB of lower level.
  • Jeremygb
    April 21, 2006 at 11:17 am
    Man, that is depressing.
    Sigh.
    If only I’d known to Google “AG-DVC30 ‘low audio'” before I bought it, I’d have found this page:
    https://www.camcorderinfo.com/bbs/t115691.html
    Sigh.
