Activity Forums Apple Final Cut Pro Legacy low audio levels when log and capturing
  • low audio levels when log and capturing
    Posted by Mike Kaufman on April 23, 2005 at 4:21 pm
    My audio levels are always very low when I log and Capture audio. I notice there is a gain adjustment slider, however it is always greyed out. How can I make this active?
    Jerry Hofmann replied 21 years, 5 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    April 23, 2005 at 4:28 pm
    FCP 5 will allow you to raise levels while capturing, however FCP 4 won’t… I’d suggest you record with more level in the first place, or you can duplicate your audio clips so that you can raise level during editing if raising just one layer of this audio isn’t enough.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jerry Hofmann
    April 23, 2005 at 7:50 pm
    Of course you could capture the material twice… and use the analog outs thru another camera/capture card/IO/box and raise the levels on the way with a mixer. We are talking DV system here right?
    Jerry
