Activity Forums VEGAS Pro Low audio levels when exported to DVDA
  • Low audio levels when exported to DVDA
    Posted by Lee Mceachern on May 4, 2006 at 10:36 pm
    I seem to always be jumping through hoops to get audio with suffient volume exported from Vegas to DVDA. I can have a project in Vegas with excellent audio and almost full peaks on the timeline, but when I export that audio as an AC3 file for a DVD, it shows up with very small peaks in DVDA. I have to go back to Vegas, double-up the audio tracks, crank up the audio envelope, and slide the volume slider way up, and normalize the export to -10 dB rather than the default -27 dB just to get barely acceptable audio levels when it gets into DVDA. I must be doing something wrong. Any thoughts?
    Gary Kleiner replied 20 years, 4 months ago 3 Members · 4 Replies
  • Gary Kleiner
    May 4, 2006 at 11:33 pm
    When you encode your AC3 file, set the Dialog normalization to -31db and Preprocesssing>line mode profile to none.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Tevya Washburn
    May 5, 2006 at 2:55 pm
    Gary, can you explain why Vegas is setup the way it is, and why the settings you suggest make a difference? I know DVD’s have a lower volume and that, but the default just seems way low. I’ve been cranking mine up to -31 as you suggest, but am still not sure if that’s a good thing to do?
    –the Fiddler
  • Lee Mceachern
    May 5, 2006 at 5:46 pm
    Worked like a charm. Much appreciated.
    Lee
  • Gary Kleiner
    May 7, 2006 at 6:00 am
    [theFiddler] ” I’ve been cranking mine up to -31 as you suggest, but am still not sure if that’s a good thing to do?”
    Yes, Sony suggests that you do.
    Gary Kleiner
