Activity › Forums › Adobe Premiere Pro › low audio from P2 cards
  • low audio from P2 cards
    Posted by Bruce Scott on April 4, 2012 at 7:58 pm
    Does anyone know why MXF audio files would be extremely low when imported from a P2 card into Premier Pro? The levels are perfect when viewed on the P2 Viewer.
    Richard
    Bob Woodhead replied 14 years, 5 months ago 4 Members · 4 Replies
  • Alex Udell
    April 4, 2012 at 8:19 pm
    How many tracks of audio does the clip have?
    Which ones are you monitoring?
    Alex
  • Bruce Scott
    April 4, 2012 at 9:49 pm
    Alex:
    We captured 4 channels, but channel one is the only one we really need. We are monitoring 1 and 2 in the P2 viewer and they sound and look good on the meter. We also have a Velocity HD system and when imported into Velocity the audio is perfect. We are new to Premier Pro and must have something set wrong.
    Richard
  • Shane Ross
    April 4, 2012 at 11:14 pm
    Monitor each channel separately. One at a time. You might be getting phase cancellation
    Shane
    Little Frog Post
  • Bob Woodhead
    April 5, 2012 at 3:33 am
    Someone at the P2 factory probably wired the memory wrong…. got the hot leads swapped on the audio. Happens all the time. I think if you put the card in backwards it’ll fix it.
