Activity Forums Apple Final Cut Pro Legacy low audio DSR-1500A
  • low audio DSR-1500A
    Posted by Melissa on April 14, 2005 at 8:16 pm
    Hello
    I am using the DSR-1500A a DV cam deck to capture media onto my computer. I can’t adjust the audio output levels for some reason, and they are just a little low. I realize it’s probably a simple setting in the menu but I cant seem to find it. Any one know what to do?
    Thanks!!!
    Melissa
    David Bogie replied 21 years, 5 months ago 3 Members · 3 Replies
  • Tony
    April 14, 2005 at 8:29 pm
    If you are capturing via firewire you will not have any audio level control during capture.
    You will have to adjust the levels in your sequence afterwards.
    Tony Salgado
  • Melissa
    April 14, 2005 at 9:08 pm
    Is it possible that my FCP HD capture setting are wrong because we’ve been comparing all kinds of tapes and they are all low.
  • David Bogie
    April 14, 2005 at 10:30 pm
    No settings control the input. FW input is just a file transfer. You recorded the signal too low on your tape. You can route the signal out through a mixer, boost the audio, and pipe it back in through another DV-to-FW deck.
    But anyway you cut this, there is no getting around it: your tapes were recorded improperly.
    bogiesan
