Activity Forums VEGAS Pro Loud volume-filter
  • Loud volume-filter
    Posted by Anton Louthander on August 16, 2015 at 6:57 pm
    Hello!
    I’m trying to find a Vegas plugin that filter away the loud parts of an audio clip. Mainly what I will use it for is to remove the clamp sound of footsteps to make them sound sneaky. I’ve done an example of what I mean with some volume automation here:
    Is there any plugin that does this kind of thing? I’m not sure if it’s called filter or whatever, but it would make my sound designing a lot easier.
    Regards,
    Anton
    Wayne Waag replied 11 years, 1 month ago 2 Members · 3 Replies
  • Wayne Waag
    August 16, 2015 at 7:30 pm
    Try using the track compressor which is automatically applied to all tracks by default. Just play around the threshold and the amount of compression. It can also be applied to specific audio events if you don’t it applied to the entire track.
    wwaag
  • Anton Louthander
    August 16, 2015 at 7:46 pm
    I tried using the track compressor, but it wasn’t of satisfaction. But now I actually found that my added plugin Izotope RX2 Declicker got the job done.
    Thank you for such a quick answer wwaag!
  • Wayne Waag
    August 16, 2015 at 10:04 pm
    Glad you solved your problem. Izotope is really great.
    wwaag
