Activity › Forums › Apple Final Cut Pro Legacy › LOUD Audio blasting out of my speakers in trim mode
  • LOUD Audio blasting out of my speakers in trim mode
    Posted by Ken Jones on December 8, 2009 at 6:25 pm
    I have had this problem in the past but it seems to be getting worse/happening more often. Whenever I am in trim mode in FCP the audio sometimes go berserk around the trim point. It blasts a bunch of VERY LOUD digital noise out of my speakers and doesn’t stop until I hit the space bar to stop playback. I then try to trim again and it acts normal. It doesn’t happen on a regular basis but it scares me to death every time it does it. Maybe it is a problem with audio output on my Blackmagic card?
    FCP 7.0.1
    Mac OS 10.6.2
    Blackmagic Decklink Extreme (7.3.2 drivers)
    Jerry Hofmann replied 16 years, 9 months ago 3 Members · 3 Replies
  • John Pale
    December 9, 2009 at 1:56 pm
    Toggle the sound Output preferences in your System Preferences (not the Blackmagic PrefPane…the System PrefPane). I was getting similar sounds when I first installed the drivers, this fixed it.
  • Jerry Hofmann
    December 9, 2009 at 1:58 pm
    The audio likely goes through some command in the software. That is a mode you enter… sort of like an applet. so ask BM about this… I can say I don’t have the problem with AJA or Matrox products I have around here.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Jerry Hofmann
    December 9, 2009 at 2:00 pm
    Ah! you may have saved the day.
    Jerry
