Activity Forums Maxon Cinema 4D Lots of points, lots of splines… and xpresso
  • Lots of points, lots of splines… and xpresso
    Posted by Brian Smith on February 10, 2012 at 12:41 am
    Hey all-
    I have a comp of 82 different points. From each point, I need to grow a spline to each of the other 81 points. I believe this equals something over 6700 individual splines so I would prefer not to do it manually if at all possible (copying and pasting position coordinates.) I know my way around xpresso a bit and I think the solution lies there. However, my experiments have not come up with anything that works.
    Any ideas?
    Brian Smith replied 14 years, 7 months ago 3 Members · 5 Replies
  • Randy Johnson
    February 10, 2012 at 7:33 am
    I think you are going to need to script that. You could create several (80) levels and use a cloner but it sounds like you need something closer to what say IVY GROWER plug in does….
    /Randy
  • Brian Jones
    February 10, 2012 at 3:59 pm
    maybe UberTracer (https://www.genemagtoto.com/c4dplugins/) will do what you want. There are some demo scenes on this thread – https://www.c4dcafe.com/ipb/topic/55657-ubertracer-plugin-free-r11-r115-r12/
    – Limit Distance is on by default and Max Line Length will make it look like it’s not working if things are too far apart
  • Brian Smith
    February 10, 2012 at 5:10 pm
    Randy- I was afraid of that. I was sitting at home last night thinking about it, I started to realize that the solution was probably in Python. Either that or processing… something I have no idea how to do.
  • Brian Smith
    February 10, 2012 at 5:12 pm
    Brian-
    Thanks for this! I’ve never heard of this, but it’s great. I made something similar to this yesterday with Xpresso, but the time it took to replicate everything was not awesome. Since this is a short turn around, this is probably the solution I’ll use.
    Thanks for your help!
    -BS
  • Brian Smith
    February 10, 2012 at 5:16 pm
    Correction…. I just opened started playing with it and realized this just shaved probably a whole day of work off. This is EXACTLY what I was looking for. You just saved my bacon!
    Thanks a million!
