Lots of Lag in Timeline Editor
Posted by Scottie Haines on February 24, 2019 at 8:18 pmI’m wondering if someone could point me in the right direction here. I create something called virtual choirs. These include many tracks at one time. The project I am currently working on has 112 tracks (56 videos, 56 audio). I use Vegas to edit tracks in the track editing stage of the process so that the video and audio remain synced when I stretch and shrink snippets of each track. I am experiencing heavy lag in the editor, but I’m not sure why. My processor isn’t being worked hard at all, my hard drives aren’t spiking, my graphics cards aren’t spiking, my memory has plenty of headroom. I’m not sure where the bottleneck is that causes this terrible amount of lag. When I say lag, I’m talking about the resizing/stretching or moving of clips in the timeline editor.
Here are some of my specs:
Intel i7-3820 4-core/8-thread processor @ 3.6 GHz
32 GB Memory
Windows/Software – 3 Raided SSDs
Tracks – 4 Raided SSDs
Graphics – GTX 580 x2
Motherboard – GA-X79-UP4George Dean replied 7 years, 7 months ago 3 Members · 9 Replies -
Ole Kristiansen
February 24, 2019 at 8:36 pmHi Scottie !
I think you forgot about which version of Vegas you are using and media info about your footage!
Best,
Ole -
George Dean
February 24, 2019 at 9:01 pmAlso Scottie, as Ole requested can you set Mediainfo in Text mode (under the ‘View’ tab), and provide a screenshot of your project settings?
Best Regards……George
Scottie Haines
February 24, 2019 at 9:39 pm -
George Dean
February 24, 2019 at 9:59 pmScottie, download the free app Mediainfo here: https://mediaarea.net/en/MediaInfo
Start Mediainfo, at the top select the ‘View’ tab, then the ‘Text’ mode from the drop down. Then select the ‘File’ and find your source media and load it. It will display a long list of metadata for both the video and audio. Copy and paste that here (or a screenshot). From those specs, we may discover why your issue and make a suggestion.
Sorry for the confusion from previous posts.
Scottie Haines
February 24, 2019 at 10:09 pmGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Andrew Gerle.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp41/mp42/isom)
File size : 238 MiB
Duration : 3 min 26 s
Overall bit rate mode : Variable
Overall bit rate : 9 701 kb/s
Movie name : My Movie 1
Movie_More : This video is about My Movie 1
Encoded date : UTC 2019-01-22 18:39:46
Tagged date : UTC 2019-01-22 18:40:14
thmb : ÿØÿàVideo
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 2 frames
Format settings, GOP : M=1, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 9 467 kb/s
Maximum bit rate : 768 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.428
Stream size : 233 MiB (98%)
Title : Core Media Video
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcCAudio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Source duration : 3 min 26 s
Bit rate mode : Constant
Bit rate : 226 kb/s
Nominal bit rate : 256 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 5.56 MiB (2%)
Source stream size : 5.56 MiB (2%)
Title : Core Media Audio
Language : English
Tagged date : UTC 2019-01-22 18:40:14General
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Andrew Gerle.mp4.sfk
File size : 302 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Boyd Jackson.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 0000.00 (qt )
File size : 193 MiB
Overall bit rate : 7 850 kb/s
Encoded date : UTC 2018-12-03 00:06:49
Tagged date : UTC 2018-12-03 00:10:15
Writing library : Apple QuickTimeVideo
Format : AVC
Format settings, GOP : M=2, N=30
Codec ID : avc1
Bit rate : 7 785 kb/s
Width : 1 080 pixels
Height : 720 pixels
Display aspect ratio : 3:2
Frame rate : 30.000 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.334
Stream size : 191 MiB (99%)
Matrix coefficients : BT.601
Format : AAC LC
Bit rate : 64.0 kb/s
Channel(s) : 1 channel
Channel layout : C
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Stream size : 1.55 MiB (1%)
Source stream size : 1.55 MiB (1%)
Tagged date : UTC 2018-12-03 00:10:15General
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Boyd Jackson.mov.sfk
File size : 139 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Eli Mitchell-Larson.mov
Format : MPEG-4
File size : 268 MiB
Duration : 3 min 27 s
Overall bit rate : 10.8 Mb/s
Encoded date : UTC 2018-12-28 19:13:23
Tagged date : UTC 2018-12-28 19:13:26
com.apple.quicktime.make : Apple
com.apple.quicktime.model : MacBookPro13,1
com.apple.quicktime.software : Mac OS X 10.14.2 (18C54)
com.apple.quicktime.creationdate : 2018-12-28T14:09:36-0500Video
Format : AVC
Format profile : Main@L3.1
Format settings, GOP : M=2, N=12
Codec ID : avc1
Bit rate : 10.5 Mb/s
Height : 720 pixels
Frame rate mode : Variable
Frame rate : 12.053 FPS
Minimum frame rate : 12.048 FPS
Maximum frame rate : 12.058 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.945
Stream size : 260 MiB (97%)
Format : AAC LC
Source duration : 3 min 27 s
Nominal bit rate : 320 kb/s
Source stream size : 7.18 MiB (3%)
Tagged date : UTC 2018-12-28 19:13:26General
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Eli Mitchell-Larson.mov.sfk
File size : 279 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Emily Everlith.mov
Format : MPEG-4
File size : 186 MiB
Duration : 3 min 28 s
Overall bit rate : 7 501 kb/s
Encoded date : UTC 2019-01-18 22:52:05
Tagged date : UTC 2019-01-18 22:55:34
Format : AVC
Codec ID : avc1
Bit rate : 7 436 kb/s
Height : 720 pixels
Frame rate : 28.669 FPS
Minimum frame rate : 5.000 FPS
Maximum frame rate : 30.000 FPS
Original frame rate : 25.000 FPS
Color space : YUV
Bit depth : 8 bits
Stream size : 185 MiB (99%)
Format : AAC LC
Source duration : 3 min 28 s
Channel layout : C
Stream size : 1.56 MiB (1%)
Source stream size : 1.56 MiB (1%)
Tagged date : UTC 2019-01-18 22:55:34General
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Emily Everlith.mov.sfk
File size : 140 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Jake Gluckman.mov
Format : MPEG-4
File size : 266 MiB
Duration : 3 min 24 s
Overall bit rate : 10.9 Mb/s
Encoded date : UTC 2018-11-18 04:03:57
Tagged date : UTC 2018-11-18 04:04:06
com.apple.quicktime.model : MacBookPro11,4
com.apple.quicktime.software : Mac OS X 10.12.3 (16D32)
com.apple.quicktime.creationdate : 2018-11-17T22:58:48-0500Video
Format : AVC
Format settings, GOP : M=2, N=29
Codec ID : avc1
Height : 720 pixels
Frame rate : 29.898 FPS
Minimum frame rate : 9.993 FPS
Maximum frame rate : 30.030 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.382
Stream size : 257 MiB (97%)
Source stream size : 259 MiB (97%)
Format : AAC LC
Source duration : 3 min 24 s
Bit rate : 278 kb/s
Stream size : 6.80 MiB (3%)
Source stream size : 6.80 MiB (3%)
Tagged date : UTC 2018-11-18 04:04:06General
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Jake Gluckman.mov.sfk
File size : 276 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – John Paciga.mov
Format : MPEG-4
File size : 189 MiB
Duration : 3 min 22 s
Overall bit rate : 7 859 kb/s
Encoded date : UTC 2018-11-18 17:45:59
Tagged date : UTC 2018-11-18 17:49:21
Format : AVC
Codec ID : avc1
Bit rate : 7 792 kb/s
Height : 720 pixels
Frame rate : 30.085 FPS
Minimum frame rate : 15.385 FPS
Maximum frame rate : 31.579 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.333
Stream size : 188 MiB (99%)
Format : AAC LC
Source duration : 3 min 22 s
Channel layout : C
Stream size : 1.53 MiB (1%)
Source stream size : 1.53 MiB (1%)
Tagged date : UTC 2018-11-18 17:49:21General
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – John Paciga.mov.sfk
File size : 136 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Joshua Gitelson.mp4
Format : MPEG-4
Codec ID : mp42 (isom/mp42)
File size : 424 MiB
Duration : 3 min 25 s
Overall bit rate : 17.3 Mb/s
Encoded date : UTC 2018-11-14 17:11:35
Tagged date : UTC 2018-11-14 17:11:35
xyz : +40.8033-077.8344/
com.android.version : 7.0Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 1 Ref Frames
Format settings, RefFrames : 1 frame
Codec ID : avc1
Source duration : 3 min 25 s
Bit rate : 17.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Rotation : 90°
Minimum frame rate : 26.300 FPS
Maximum frame rate : 34.629 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.273
Stream size : 417 MiB (98%)
Source stream size : 417 MiB (98%)
Title : VideoHandle
Language : English
mdhd_Duration : 205787
Format : AAC LC
Bit rate : 256 kb/s
Stream size : 6.28 MiB (1%)
Title : SoundHandle
Language : English
Tagged date : UTC 2018-11-14 17:11:35General
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Joshua Gitelson.mp4.sfk
File size : 301 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Laura Lathem.mp4
Format : MPEG-4
Codec ID : mp42 (mp41/isom)
File size : 192 MiB
Overall bit rate mode : Constant
Overall bit rate : 7 877 kb/s
Encoded date : UTC 2018-11-19 03:28:54
Tagged date : UTC 2018-11-19 03:28:54Video
Format : AVC
Format settings, GOP : M=3, N=30
Codec ID : avc1
Bit rate : 7 899 kb/s
Height : 720 pixels
Frame rate : 29.335 FPS
Minimum frame rate : 20.804 FPS
Maximum frame rate : 31.646 FPS
Original frame rate : 30.000 FPS
Standard : Component
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.292
Stream size : 188 MiB (98%)
Color range : Full
Format : AAC LC
Bit rate : 161 kb/s
Nominal bit rate : 192 kb/s
Stream size : 3.94 MiB (2%)
Source stream size : 3.94 MiB (2%)
mdhd_Duration : 204775General
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Laura Lathem.mp4.sfk
File size : 300 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Rob Bell.mov
Format : MPEG-4
File size : 86.2 MiB
Duration : 3 min 14 s
Overall bit rate : 3 724 kb/s
Encoded date : UTC 2018-11-15 23:08:19
Tagged date : UTC 2018-11-15 23:08:26
com.apple.quicktime.model : MacBookPro5,1
com.apple.quicktime.software : Mac OS X 10.11.6 (15G17023)
com.apple.quicktime.creationdate : 2018-11-15T14:57:46-0800Video
Format : AVC
Codec ID : avc1
Bit rate : 3 440 kb/s
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 5.382 FPS
Minimum frame rate : 2.495 FPS
Maximum frame rate : 15.000 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 2.081
Stream size : 79.6 MiB (92%)
Format : AAC LC
Source duration : 3 min 11 s
Source stream size : 6.50 MiB (8%)
Tagged date : UTC 2018-11-15 23:08:26General
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Rob Bell.mov.sfk
File size : 258 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Tavi Wolfwood.mov
Format : MPEG-4
File size : 260 MiB
Duration : 3 min 21 s
Encoded date : UTC 2018-11-19 03:25:25
Tagged date : UTC 2018-11-19 03:25:36
com.apple.quicktime.model : MacBookAir6,2
com.apple.quicktime.software : Mac OS X 10.11.6 (15G20015)
com.apple.quicktime.creationdate : 2018-11-18T22:20:49-0500Video
Format : AVC
Codec ID : avc1
Height : 720 pixels
Frame rate : 29.970 (29970/1000) FPS
Minimum frame rate : 10.885 FPS
Maximum frame rate : 36.765 FPS
Color space : YUV
Bit depth : 8 bits
Stream size : 254 MiB (97%)
Source stream size : 254 MiB (98%)
Format : AAC LC
Source duration : 3 min 21 s
Bit rate : 254 kb/s
Stream size : 6.11 MiB (2%)
Source stream size : 6.11 MiB (2%)
Tagged date : UTC 2018-11-19 03:25:36General
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Tavi Wolfwood.mov.sfk
File size : 271 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Thomas Harvey.MOV
Format : MPEG-4
File size : 16.8 MiB
Overall bit rate : 686 kb/s
Encoded date : UTC 2018-11-07 18:45:37
Tagged date : UTC 2018-11-07 18:45:56
com.apple.quicktime.location.ISO6709 : +29.9515-090.0680+002.249/
com.apple.quicktime.model : iPad Pro
com.apple.quicktime.software : 12.0.1
com.apple.quicktime.creationdate : 2018-11-07T12:39:06-0600Video
Format : AVC
Format profile : Baseline@L3
Format settings : 1 Ref Frames
Format settings, CABAC : No
Codec ID : avc1
Bit rate : 559 kb/s
Width : 568 pixels
Height : 320 pixels
Rotation : 180°
Minimum frame rate : 30.000 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.103
Stream size : 13.7 MiB (82%)
Format : AAC LC
Bit rate : 98.0 kb/s
Channel layout : C
Stream size : 2.41 MiB (14%)
Source stream size : 2.41 MiB (14%)
Tagged date : UTC 2018-11-07 18:45:56Other #1
Type : meta
Bit rate mode : VBROther #2
Type : meta
Duration : 3 min 25 sGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Thomas Harvey.MOV.sfk
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Yara El-Khatib.mov
Format : MPEG-4
File size : 186 MiB
Duration : 3 min 19 s
Overall bit rate : 7 815 kb/s
Encoded date : UTC 2019-01-22 17:08:15
Tagged date : UTC 2019-01-22 17:11:34
Format : AVC
Codec ID : avc1
Bit rate : 7 746 kb/s
Height : 720 pixels
Frame rate : 29.851 FPS
Minimum frame rate : 9.375 FPS
Color space : YUV
Bit depth : 8 bits
Stream size : 184 MiB (99%)
Format : AAC LC
Duration : 3 min 18 s
Source duration : 3 min 18 s
Channel layout : C
Stream size : 1.51 MiB (1%)
Source stream size : 1.51 MiB (1%)
Tagged date : UTC 2019-01-22 17:11:34General
Complete name : W:\Spizzwinks\Tracks (Raw)\I – Tenor 1\T1 – Yara El-Khatib.mov.sfk
File size : 134 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\II – Tenor 2\T2 – Ben Watsky.mp4
Format : MPEG-4
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 46.3 MiB
Overall bit rate : 1 864 kb/s
Writing application : Lavf58.12.100Video
Format : AVC
Format profile : Baseline@L3.1
Format settings : 2 Ref Frames
Format settings, GOP : M=1, N=103
Codec ID : avc1
Bit rate : 1 751 kb/s
Height : 720 pixels
Frame rate : 24.000 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.079
Stream size : 43.5 MiB (94%)
Language : English
Format : AAC LC
Bit rate : 106 kb/s
Maximum bit rate : 128 kb/s
Channel layout : C
Stream size : 2.64 MiB (6%)
Language : English
Default : Yes
Alternate group : 1General
Complete name : W:\Spizzwinks\Tracks (Raw)\II – Tenor 2\T2 – Ben Watsky.mp4.sfk
File size : 152 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\II – Tenor 2\T2 – Brandon Levin.mov
Format : MPEG-4
File size : 151 MiB
Duration : 3 min 20 s
Overall bit rate : 6 294 kb/s
Encoded date : UTC 2018-12-02 20:42:42
Tagged date : UTC 2018-12-02 20:46:03
Format : AVC
Codec ID : avc1
Bit rate : 6 222 kb/s
Height : 720 pixels
Minimum frame rate : 12.000 FPS
Maximum frame rate : 25.000 FPS
Color space : YUV
Bit depth : 8 bits
Stream size : 149 MiB (99%)
Format : AAC LC
Source duration : 3 min 20 s
Channel layout : C
Tagged date : UTC 2018-12-02 20:46:03General
Complete name : W:\Spizzwinks\Tracks (Raw)\II – Tenor 2\T2 – Brandon Levin.mov.sfk
File size : 135 KiBGeneral
Complete name : W:\Spizzwinks\Tracks (Raw)\II – Tenor 2\T2 – Derek Demel.mp4
Format : MPEG-4
Codec ID : mp42 (isom/iso2/avc1/mp41)
File size : 159 MiB
Overall bit rate : 6 617 kb/s
Encoded date : UTC 2019-02-20 23:38:19
Tagged date : UTC 2019-02-20 23:38:19
Writing application : HandBrake 1.2.0 2018121700Video
Format : AVC
Format settings : CABAC / 4 Ref Frames
Format settings, RefFrames : 4 frames
Codec ID : avc1
Bit rate : 6 457 kb/s
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.346
Stream size : 156 MiB (98%)
Writing library : x264 core 157 r2935 545de2f
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=14000 / vbv_bufsize=14000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Format : AAC LC
Bit rate : 152 kb/s
Channel layout : C
Stream size : 3.65 MiB (2%)
Title : Mono
Default : Yes
Alternate group : 1
Tagged date : UTC 2019-02-20 23:38:19General
Complete name : W:\Spizzwinks\Tracks (Raw)\II – Tenor 2\T2 – Derek Demel.mp4.sfk
Complete name : W:\Spizzwinks\Tracks (Raw)\II – Tenor 2\T2 – Devin Caughey.mov
Format : MPEG-4
File size : 266 MiB
Encoded date : UTC 2019-01-10 19:43:22
Tagged date : UTC 2019-01-10 19:43:33
com.apple.quicktime.model : MacBookPro14,2
com.apple.quicktime.software : Mac OS X 10.13.6 (17G4015)
com.apple.quicktime.creationdate : 2019-01-10T14:35:26-0500Video
Format : AVC
Codec ID : avc1
Height : 720 pixels
Minimum frame rate : 15.000 FPS
Maximum frame rate : 44.978 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.381
Source stream size : 258 MiB (97%)
Format : AAC LC
Source stream size : 7.46 MiB (3%)
Tagged date : UTC 2019-01-10 19:43:33General
Complete name : W:\Spizzwinks\Tracks (Raw)\II – Tenor 2\T2 – Devin Caughey.mov.sfk
Complete name : W:\Spizzwinks\Tracks (Raw)\II – Tenor 2\T2 – Devin Dolquist.mov
Format : MPEG-4
File size : 8.22 MiB
Overall bit rate : 340 kb/s
Movie name : Somewhere – Devin Dolquist
Description : This video is about My Movie
Encoded date : UTC 2018-11-09 21:25:36
Tagged date : UTC 2018-11-09 21:25:36
Keyword : iMovie
com.apple.quicktime.keywords : iMovie
com.apple.quicktime.title : Somewhere – Devin DolquistVideo
Format : AVC
Format profile : High@L2.1
Codec ID : avc1
Bit rate : 271 kb/s
Width : 428 pixels
Height : 240 pixels
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.088
Stream size -
Scottie Haines
February 24, 2019 at 10:11 pmThat is all the tracks involved. I should mention that when I am getting the lagging problems, I only have one track solo’d at a given time during editing. I am not playing multiple tracks. Just a video and audio set.
George Dean
February 24, 2019 at 11:06 pmScottie,
Thank You for posting the source media file specs.
First you may want to update your Vegas pro as the latest build is 361.
If I understand correctly you can play the solo track at normal speed, correct? At what preview quality is your Preview set for? Your complaint is when your trim or move an event on a solo’ed track it lags behind your movement, is that correct?
Out of curiosity, what kind of cameras are you using to record your source media?
You have quite the mix of resolutions, display ratios, and frame rates, with many having variable frame rates. Vegas (and most NLE’s) do not like variable frame rates, and it would be best if you could covert to constant frame rates.
Scottie Haines
February 24, 2019 at 11:22 pmI guess I thought Vegas updates itself. I haven’t been prompted for an update. Yes, for my next virtual choir project, I plan to handbrake every incoming video, regardless of original specs. I only just discovered handbrake halfway into editing.
Yes, playback usually isn’t an issue, although sometimes there is just a touch of a wait before it plays, but it’s within a reasonable amount most times. Resolution of preview, or even muting video altogether, doesn’t have an effect.
Source videos came from webcams and mobile devices. The sources really span the gamut unfortunately.
The video is really just tagging along with the audio for edits. They will be rendered out individually at the end of the process. Is it possible that Vegas is keeping track of other tracks even though they are muted?
What is the best way to keep Vegas updated?
George Dean
February 25, 2019 at 12:07 amI’m not sure what Vegas does when you solo a track, it could be that Vegas just kills the previewer when solo’ed, good question above my current pay grade! You could try instead of sole’ing a track, actually mute all the tracks except the one you are working on as a test to see if there is any difference. However, I would assume (you know how much trouble that can cause!!), like yourself that when you solo the track, you relieve the engine of the other tracks. I surprised with your 4 core CPU you are not having more issues with playback on some of the events, but that would be another issue that you fortunately don’t have.
As for keeping up with the updates…..Vegas Pro 16 has an option under the ‘Help’ tab to check for updates. I haven’t had the best of luck with that feature, so I keep up with it via this or other forums.
Sorry to have asked so many questions and you have been excellent at answering and posting that information, and other than transcoding/converting your source media to a common constant frame rate, as you intend to do with Handbrake, I cannot offer much more at this point. Maybe other user here has a suggestion.
