Activity › Forums › Apple Final Cut Pro Legacy › Lost two Lacie 250’s in two days need enclosure recommendations.
  • Mark Maness
    May 31, 2006 at 9:14 pm
    So far, G-Raids are the most reliable external drives on the market. I haven’t heard of any complaints about G-Raids.
    _______________________________
    Wayne Carey
    Schazam Productions
  • Khashyar Darvich
    Sorry about the problems with the Lacie drives. I have heard of similar stories with Lacie hard drives.
    I use a G-tech, and I have been happy with it, and have had no problems with it thus far. I also have a friend in a recording studio who uses G-tech, also with no problems.
    It’s fortunate that you could save your date.
    Good luck,
    Khashyar
  • Steven Gonzales
    May 31, 2006 at 9:39 pm
    I’ve had no problems with wiebetech.com enclosures.
  • Aaron Neitz
    May 31, 2006 at 11:19 pm
    We lost 2 Lacie 500 GB drives.
    We only use G-Tech now – can’t recommend them enough.
  • Rich Rubasch
    June 1, 2006 at 12:42 am
    For a custom enclosure I found a little gem is StorCase.com and they will make an enclosure to your specifications. Mine has run continuously for 2 years without a hiccup….I’m going to knock wood now.
    Rich Rubasch
    Tilt Media
  • Shawn Bockoven
    June 1, 2006 at 1:57 am
    Thank you all.
    SB
  • Andrew Commiskey
    June 1, 2006 at 1:59 am
    I have had no problems with OWC drives and cases in 6 years. (www.macsales.com)
    Drew
    Chaos is the beginning of everything.
  • Ben Holmes
    June 1, 2006 at 9:52 am
    What was the problem? I have had two Lacie drives fail because the firewire connections on the back came loose. A bit of soldering sorted it, but the design is flimsy to say the least…. I’ve switched to G-raid.
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations.
    Producer/Director “The Supercar Run” now available for international distribution from http://www.electricsky.com
  • Tom Matthies
    June 1, 2006 at 1:27 pm
    I’m still running six LaCie drives and will until they fail. I won’t replace them with more LaCies however. I’ve added a G-Raid and a Huge Sysrems raid in the last year. No problems with either.
    Tom
  • Ben Oliver
    June 1, 2006 at 3:24 pm
    I LOVE LACIE. nuff said.
