Activity Forums VEGAS Pro Lost Trimmer
  • Lost Trimmer
    Posted by Gary & yvonne on June 20, 2006 at 6:10 am
    I can’t get the trimmer to come on…..I can get everything else on the bottom tool bar to be on….view monitor, media generator, mixer, explorer…., I’ve tried several methods…under VIEW making sure trimmer is checked, clicking on trimmer…using the keyboard keys alternate+2 and also even tried to starting vegas with the default keys control-D release 1 but that didn’t change it back to default settings. Appreciate your help. Thanks, Gary
    Gary & yvonne replied 20 years, 2 months ago 2 Members · 2 Replies
  • Edward Troxel
    June 20, 2006 at 1:37 pm
    It’s Alt-D 1 (not CTRL)
    Beyond that, you’ve probably moved it off the screen. Change to a higher screen resolution, find it an move it back, and the reset the screen resolution.
    Or you can take the “brute force” method – Hold down CTRL-SHIFT while starting Vegas which will totally reset it to factory defaults.
    Edward Troxel
    JETDV Scripts
  • Gary & yvonne
    June 20, 2006 at 8:02 pm
    Thanks Edward found it….it was off the screen at the bottom.
    I hope your feeling better……..Gary
