Activity Forums VEGAS Pro lost trim or slip edit visual feedback in preview!!!
  • lost trim or slip edit visual feedback in preview!!!
    Posted by Erik Davis on November 6, 2016 at 6:28 am
    Hi, this will really give me some relief if someone can point me in the right direction. I like to trim or slip my edits by watching the preview window and SEEING the exact edit point as I drag the event clip. Somehow! I have lost this ability in Vegas13. When I am actively trimming a clip my preview window only shows black! Not the clip as it is being adjusted. I can’t edit like this. Please someone help me!
    Erik
    Erik Davis replied 9 years, 10 months ago 4 Members · 6 Replies
  • Richard Jones
    November 6, 2016 at 9:53 am
    Have you disabled the FX By Pass button (the circle with a vertical line through it) which appears above the Preview window)? Play with its drop down menu and you may find the solution.
    Richard
  • Erik Davis
    November 6, 2016 at 1:38 pm
    Hi Richard,
    No unfortunately, this did not help my problem. Still stumped. Works on other versions of Vegas but not 13 so it must be either a setting or a problem with the install of Vegas13?
    Erik
  • George Dean
    November 6, 2016 at 3:02 pm
    Hi Erik,
    Are using the ‘Normal Edit Tool’ when you are doing this?
    Do you usually have ‘Auto Ripple’ On or Off?
    Best Regards…..George
  • Erik Davis
    November 6, 2016 at 3:04 pm
    Yes George, I am using the normal edit tool. Ripple would usually be off in this situation but the preview windows should show trimming visual feedback with it on as well.
  • Aleksey Tarasov
    November 6, 2016 at 3:07 pm
    Turn on View > Video Event Edge Edit Frames
  • Erik Davis
    November 6, 2016 at 3:10 pm
    Ding ding ding!!!! We have a answer!!!!!!!!
    Thanks!!! I never saw that in Vegas and I have been using this program since 2008! Somehow it never got turned off before and somehow even more amazingly I don’t ever recall seeing it under the “view” tab. A thousand thank yous!
