Activity › Forums › Apple Final Cut Pro Legacy › Lost Sequence?
Lost Sequence?
Posted by Chris Babbitt on March 15, 2011 at 5:48 pmThis probably belongs in the Basics forum, but I have been an FCP user since day one, and have never encountered this problem. I went back to make some tweeks to a previously completed project, and the timeline doesn’t appear and there is no icon for the sequence in the browser. Is it possible to lose, hide or accidentally delete your main sequence?
Dan Monro replied 15 years, 6 months ago 5 Members · 9 Replies -
Rafael Amador
March 15, 2011 at 6:09 pmHi Chris,
You know well that the only acceptable reason should be “accidental deleting”.
Did you already had a look to the Autosaved sequences?
rafael -
Chris Babbitt
March 15, 2011 at 6:17 pmSorry to say that I don’t use Autosave. There were so many problems early-on that I stopped using it and never went back. I would think that it should be more difficult to accidentally delete a sequence.
Tom Matthies
March 15, 2011 at 7:57 pmDid you drag it onto another folder by mistake?
TomE=MC2+/-2db
Dan Monro
March 15, 2011 at 9:29 pmYour timeline window is open, right? You just can’t find your actual sequence?
And you actually have autosave vault turned off in preferences? Its not that you just don’t pay any attention to it? Because its autosaving unless you’ve told it not to.
If you’ve told it not to autosave, surely you back your project up somewhere, right? Tell me you do…
Thumbdrive? Time machine? CD? Anything? ‘Cause if your sequence is highlighted and you hit ‘delete’ then its gone – unless you can undo. But once you’ve closed FCP you can’t undo your way back.
In which case, sorry. I hope you’ll turn autosave back on.
Good luck,
DDan Monro
FCP, Avid, AfterFX, Atlanta
MacBook Pro 2.53 GHz Intel Core i5 4 GB ram
Mac OS X 10.6.4
NVIDIA GeForce GT 330M
Final Cut Pro 7 Quicktime 7.6.6
– OR –
2 x 3.2 Quad Xeon; 16 GB ram
Mac OS X 10.6.4
NVIDIA Quadro FX 5600 Final Cut Pro 7.0.2 Quicktime 7.6.6 -
Chris Babbitt
March 15, 2011 at 9:58 pmNo sequence = no timeline window. I just can’t figure out how I could have deleted the sequence without noticing the timeline disappearing. It’s no huge loss. It was already finished and delivered. I just want to know what happened. I turned of AutoSave and have kept it off since version 3 or 4 when it was causing all sorts of problems. Is it OK now?
Rafael Amador
March 15, 2011 at 10:27 pm[Chris Babbitt] “I turned of AutoSave and have kept it off since version 3 or 4 when it was causing all sorts of problems. Is it OK now?”
If never had any problem with Autosave and has save my life a few times.
rafael -
Jeff Greenberg
March 16, 2011 at 2:45 amCould you have had two projects open…and the sequence is in the wrong project?
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website -
Dan Monro
March 16, 2011 at 12:58 pmI’ve never had a problem either, going back to version 3. I use auto save backups regularly. In fact, mine is set to every five minutes; we had some memory leak problems with huge projects, and FCP would crash often.
Just curious, what problems did it cause?
Dan Monro
Mac OS X 10.6.4
– OR –
Mac OS X 10.6.4
