Activity Forums Adobe Premiere Pro lost sequence
  • Jeff Pulera
    June 25, 2013 at 1:45 pm
    I believe that “Auto Save” is on by default and set to 20 minutes. Look in folder where project is saved – is there an “Auto Save” folder? There will be older project versions in there and perhaps you would find the sequence. Note that if you continued to have Premiere open for a long time that ALL of the usable saves could have been overwritten already, you must look right away when there is any major issue.
    If you do open an older version and find what you need, immediately do a “Save As” and save project under a new name outside the Auto Save folder, so it does not get overwritten.
    Good luck
    Jeff Pulera
    Safe Harbor Computers
