Activity Forums Adobe After Effects Lost Resolution Coming From Illustrator
  • Lost Resolution Coming From Illustrator
    Posted by Planetpopx on August 12, 2007 at 2:24 am
    This is probably a pretty basic question – but I am fairly new to these programs:
    I created a simple Adobe Illustrator file which includes a few brush strokes and some simple fonts. I can zoom in and the resolution remains perfect.
    But – when I import this into After Effects the resolution is lost. I’ve tried playing around with all of the of the different saving/importing options – yet can not seem to solve this problem.
    Any advice would be HUGELY appreciated.
    David Fleury replied 19 years, 1 month ago 3 Members · 6 Replies
  • David Fleury
    August 12, 2007 at 2:37 am
    You need to turn on your “Continuosly Rasterize” switch for that layer. Its the switch directly to the right of the Hide shy layers switch and looks like a little sun shape.
  • Planetpopx
    August 12, 2007 at 2:53 am
    Hmm…..
    That does not seem to work either.
    I’ve tried importing the file as footage – and a composition – but neither option seems to make a difference. It is still highly pixelated. Throwing the rasterize button does seem to improve the picture a little – but it is still not 100%.
  • Sam Moulton
    August 12, 2007 at 3:10 am
    make sure you don’t have PAR correction turned on in the comp window.
  • Planetpopx
    August 12, 2007 at 3:37 am
    This doesn’t seem to make a difference.
    Let me ask you – should i ever expect the resolution to be perfect? IT is perfect in Illustrator – but is this simply too much to ask of After Effects?
    Are my expectation too high? Or should Illustrator files truly translate into AE perfectly?
    I suppose i can compensate by creating larger AI files to start with – and creating larger compositions in AE – but should I really have to go through these contortions?
  • Planetpopx
    August 12, 2007 at 4:13 am
    The problem is solved.
    It would appear the the AI file will pixelate when you ZOOM in – in the composition window. That was dumb of me.
    When you SCALE the artwork itself it remains crisp.
    I apologize.
  • David Fleury
    August 15, 2007 at 4:28 am
    No need to apologize… glad you figured it out. And you gave me another point on my checklist of “Stuff that can go wrong”!
