Activity Forums Apple Final Cut Pro Lost projects / events updating from 10.0.5 to 10.0.9
  • Lost projects / events updating from 10.0.5 to 10.0.9
    Posted by Stefano Neri on September 16, 2013 at 3:10 am
    Hi!
    After upgrading from FCPX 10.0.5 to 10.0.8 I lost all my Compound Clips / Multicam Clips.
    I still have the event that was containing the clips,except the compound clips…I’m very afraid,is it possible to recover them?
    Best regards
    Jeremy Garchow replied 12 years, 11 months ago 3 Members · 2 Replies
  • Loren Risker
    September 16, 2013 at 7:34 pm
    There were some major changes to compound clips in 10.0.6.
    When upgrading, it’s a good idea to make a copy of all your currentversion.fcpevent and currentversion.fcpproject somewhere FCPX won’t see in case you need to restore.
    If you didn’t do that, hopefully there is a backup. If there is you might be able to downgrade and restore.
    OutOfFocus.TV – Original series, music videos, mini-docs.
  • Jeremy Garchow
    September 16, 2013 at 7:51 pm
    Final Cut should make a backup of the Events and Projects in an “Old Versions” folder in the Event or Project encompassing folder.
    The problem is you will need to find a version of FCP 10.0.5 to use them again.
