Activity Forums Apple Final Cut Pro Legacy Lost plug-ins
  • Posted by Jibcam on April 29, 2007 at 8:22 pm
    I just fired up my FCP 5.1.4 and when I opened up my project I received the warning “AE Effects Error: Unable to find plugin “Title Crawl” Do you wish to load the plugin from another directory?” I also receive the same warning telling me I’ve lost “3D Crawl”
    I looked for the plugin and can not find them. Where should they be stored and how can I replace them?
    Tom Meegan replied 19 years, 4 months ago 2 Members · 1 Reply
  • Tom Meegan
    April 29, 2007 at 10:55 pm
    The same thing is happening on my Mac Pro running FCP 5.1.4, OS 10.4.9 with Title 3D. Started this week, and does not happen consistently.
    This plug-in is still where it belongs on my system (library/application support/final cut pro system support/plugins) but does not load under the generator menu. That path will also lead to Title Crawl. I’m not sure what 3D Crawl is.
    As a work around I opened a sequence that had Title 3D clips in the time line, and then copied and pasted.
    Tom
