Lost my analog audio from K3 box
Had a couple of hard crashes this evening (after AJA tech support had gone home for the weekend- lucky dogs!), and suddenly I’m not getting analog audio out from the K box on my Kona 3.
Audio meters in FCP are bouncing, & audio is going to our Panny monitor via the SDI cable. We’re also getting audio out of the Mac to the mixer from i Tunes & QT, and if I set the audio in FCP to built-in audio, it plays out to the speakers as well.
I’ve swapped out cables & tried other inputs on the mixer to see if they were the problem, but still no joy in Mudville. I’ve also checked that analog video is going out through the K-box, it’s only the audio thats missing.
BTW, Playing a file in Kona TV gives the same results.
We’re using a G5 Quad with 4.5 GB of memory, running FCP 5.1.2, OS 10.4.8 & the latest Kona drivers, QT, etc.
The 1st crashed occurred while I was making a big composite in Motion. 4 tiff sequences at 720, 6 large tiffs as back plates, 1 layer of DVC Pro HD, 3 keys a couple of blurs, a little color effect… FCP was open in the background. The 2nd occurred not long after I rebooted, this time wile I was looking using Preview for a couple of pictures to use in a comp while FCP was rendering the above comp and Motion was open in the BG. I’ll admit, I was as good as asking for the 2nd crash.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog
