Activity Forums VEGAS Pro Lost in HDV
  • Lost in HDV
    Posted by Jerry Waters on June 27, 2005 at 4:39 pm
    It’s my first attempt at capturing HDV footage from a Sony Z1 in Vegas 6. Vegas sees the camera for regular DV capture but says “No Device” if I go to HDV capture. I can’t find a place to link the device in Vegas nor a menu change in the camera that works. What are the settings needed, please.
    Thanks for any help. I’m sure it is something simple I am missing.
    Jerry Waters replied 21 years, 2 months ago 2 Members · 5 Replies
  • Jerry Waters
    June 27, 2005 at 5:05 pm
    I finally got the camera firewire to “HDV” so now I’m looking for a Vegas setting.
  • Timothy Duncan
    June 27, 2005 at 5:56 pm
    If you have Vegas 6.0b, it should prompt you when you go into capture.
    For DV, select the topmost setting “Use external video capture application”
    For HDV, use the 2nd setting “Use internal video capture application”
    You can also set it under “Options/Preferences” chooosing the “video” tab. De-select the “Use external video capture application” for HDV.
    td
  • Jerry Waters
    June 27, 2005 at 6:24 pm
    I did do that and it STILL does not work. It says there is no device.
  • Timothy Duncan
    June 27, 2005 at 6:41 pm
    In your device manager, under “Sound, video and game controllers” you should have a “Sony D-VHS Device”. If not, then you need to manually install the driver for it. This is a common issue on WindowsXP Pre-Service Pack 2 systems. I personally, do not use SP2 and prefer SP1 due to many 1394 issues that have been reported with SP2.
    You can also use the manual install method with Windows2K.
    This is exactly the type of step by step things I cover in my “Vegas 6 Complete” training from Class on Demand.
    Once you get setup, it should be smooth sailing.
    td
  • Jerry Waters
    June 27, 2005 at 7:11 pm
    Thanks a lot. I just found instructions that got it working:
    1. Plug in Camera
    2. Go to Control Panel>System>Hardware>Device Manager
    3. Locate AVC/Subunit in the Device Manager
    4. Right click, choose Properties
    5. Choose Update Driver, and DO NOT let Windows go searching. Choose “I’ll find it myself” (or whatever the dialog actually says)
    6. Browse to Sound, Video, Game Controllers to find the driver
    7. Locate Sony in the list of Sound, Video, Game Controllers
    8. Open the first Sony in the list, and select the DVHS driver as the driver for your camera.
