Activity Forums Blackmagic Cameras Lost HDMI output from Micro
  • Lost HDMI output from Micro
    Posted by Luc Novovitch on March 4, 2017 at 5:37 pm
    Greetings,
    I was choosing my preferences in the Menu (frame rate etc…) when I I came to the HDMI settings. I entered this sub-menu, and the system apparently just crashed. Frozen image on the screen, buttons on the camer not responding. I was using an Atomos Ninja 2 when all that happen. Had to remove the battery to switch off the camera. Put fresh battery, restarted and no HDMI connection. I tried with the Ninja 2 and also with 2 monitors. I did record, blind, a short clip. Put the card in card reader. The recording is there, playing just fine. So, I’m lost… Read somewhere that downgrading the firmware was used when a Blackmagic camera. So question: how one does that?
    The camera is brand new. received yesterday, and opened the box this morning.
    Help and suggestion would be appreciated.
    Thank you for reading.
    Luc Novovitch replied 9 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
