Activity Forums Apple Final Cut Pro Legacy Lost firewire connections
  • Lost firewire connections
    Posted by Rennie Klymyk on September 11, 2006 at 9:20 pm
    I’m running fcp 5.0.4
    QT 7.12
    DP 2ghz G5 – (3 pci-x model)
    6 gb ram
    I usually interface through aja i/o but disconnected it and connected dsr-11 via firewire to the mac. I got an error (unable to connect to the dvcpro 50 device which it seemed to lock to even though I had changed my set up to all – dv ntsc.
    I tried using the FCP Rescue app to trash prefs
    I tried trashing my preferences as per Ken Stone manual method
    I tried deleteing all existing reciepts for QT and downloaded the 7.12 and re-installed.
    I tried 4 different cables (all of which were working fine)
    I tried hooking up a dv camera instead of the dsr-11 but same old same old.
    I tried the front and rear firewire inputs on the mac.
    I cried and I cried and I cried but that didn’t help either.
    There is nothing else connected to any firewire inputs
    I have the dsr-11 set to dv and have turned it off and on many times and it is usually playing video while I’m trying all this.
    Trashing preferences did get me out of the: error (unable to connect to the dvcpro 50 device but I now get it for the default setting of dv ntsc. ie: unable to locate the following external devices: applle firewire ntsc (720×480)
    In the A/V settings video playback shows up as [missing] applle firewire ntsc (720×480)
    In the A/V settings- A/V devices video shows up the same – [missing] applle firewire ntsc (720×480) and although the options button next to it is not greyed out, nothing happens when I click it.
    When I try to select view – all frames it reverts back to OFF imediately
    If I go to log and capture it can’t find the device and It won’t recognize it when it try capture now (please select a device in your capture presets bla bla bla.)
    Any insight as to what I am missing?
    THX
    Willi Patton replied 19 years, 10 months ago 6 Members · 21 Replies
  • 21 Replies
  • Aaron Neitz
    September 11, 2006 at 9:24 pm
    1) did you power down the ENTIRE system? (including pulling the cord so that the PMU resets)
    2) can you get the Io to work again?
    3) I know with our DSR-1500 there’s a blurb somewhere that if you connected it to a FW bus while everything was powered on, there was a chance of frying the bus.
    4) I don’t imagine you have a PCI firewire card in your system… because then you could connect to that and see if your internal bus was shot.
  • Aaron Neitz
    September 11, 2006 at 9:26 pm
    …and wait. You say DSR-11 and then DVCPRO50. The DSR-11 is DV25 only. DV50 is a purely Panasonic thing.
  • Ben Insler
    September 11, 2006 at 10:05 pm
    Sounds to me like your mac got confused when you shifted around all those cables while everything was running. Go to View::Refresh AV Devices. That should clean everything up. If not, shot down and restart with only the hardware connected that you want to use.
    Best,
    Ben
  • Rennie Klymyk
    September 11, 2006 at 10:28 pm
    Hi, I just tried pulling the plug, no change there.
    I’m trying to get the IO going again but it is not responding, the system is looking for firewire dv ntsc now even though I reset to dvcpro 50 from Io through sdi 8bit to dvcpro 50 codec. (this is my normal configuration as we use dvcpro for aquisition). Looks like I have to trash prefs again to try to re-configure the Io. I just need to capture dv for a short job. All this when I’m in the middle of a renovation in the edit room. Everything was disconnected and rolled in a corner while a wall was removed. Now I’m set up in 1/2 the space with a plastic barrier keeping out the dust from the reno, I have to re-wire the dvcpro deck, lo etc just to try it when all I want to do is the dv job, then rewire everything when it is in place after the remo.
    I don’t have a pci firewire card to try and I sure hope I didn’t fry any buses. It seems to me last time I captured dv I had a bit of hassle but all I had to do was disconnect the Io.
  • Rennie Klymyk
    September 11, 2006 at 10:32 pm
    Hi, I usually am set up for dvcpro 50 so I guess the FCP restore app saves those settings. When I manually deleted the prefs I got rid of that setting and was able to set all for dv ntsc but no recognition of the hardware. I should be able to wipe all prefs and just with one firewire into the dsr-11, configure dv ntsc but no go so far.
  • Rennie Klymyk
    September 11, 2006 at 10:50 pm
    Thanks Ben, this does nothing. I actually had it all disconected and just connected the dv deck, opened fcp and tried to reset capture and project settings but was unable to do so. I’m ready to re-install tiger and fcp on a new hard drive and go from there. I need to author a dvd from this project too.
  • Jeremy Garchow
    September 12, 2006 at 1:08 am
    Hit control-q and choose dv NTSC (or PAL) with your DSR-11 powered up and on before you launch FCP.
    Avoid the io settings because you are not using it.
    Jeremy
  • Rennie Klymyk
    September 12, 2006 at 3:41 am
    I tried it but I’m not getting any option to choose dv ntsc.
    I get:
    remove from dock
    open at log in
    show in finder
    or
    open
    if I choose open I get the same dialog ie: unable to locate external device…….
    If I go directly to the fcp app icon and not the alias in the dock I get a bigger list of options but still no dv ntsc option. If I choose open there I get the same old same old again.
  • Jeremy Garchow
    September 12, 2006 at 3:46 am
    Sorry, Rennie, open FCP first, then hit contol-q and choose dv ntsc with the DSR-11 already powered up and connected via firewire.
    Jeremy
  • Rennie Klymyk
    September 12, 2006 at 4:03 am
    Yes this does set it all up properly but I got this far before using the easy set-up link but it is still not seeing the firewire device.
    I’m thinking I could take a hammer and really smack the 6 pin connector on the end of the cable into the firewire socket it should connect.
    I’m starting to worry that CharlieX2 may be right and my firewire bus is blown. I’ve never heard of this before and I would think there must be some type of firmware zap or something to wake up the bus.
    Anyone know of a good firewire card for pci-x? It would be worth picking one up at this point.
Page 1 of 3
