Activity Forums Apple Final Cut Pro Legacy Lost files in FCP
  • Lost files in FCP
    Posted by Malcolm Brabant on January 7, 2010 at 8:33 am
    I have been cutting a 65 minute film of my son’s school play.
    The material is all on an external hard drive.
    I have twice tried to export the finished product on to the external hard drive with a file called Beauty First try.
    I exported it as a Quick Time movie.
    The film took about two hours to render.
    I tried to find the file on the external hard drive but can’t.
    Even when looking using the Mac Finder to search for newlycreated files over 5GB.
    The film has also used up stacks of space on the harddrive of my laptop.
    And I can’t find where the files have gone.
    All of the Final Cut Pro files on the laptop are empty.
    It’s not in the render file.
    Where might I look?
    I have been searching for hours and can’t find it.
    I am sure it’s something simple that I have overlooked.
    But it is doing my head in.
    best
    Malcolm.
    Adam Taylor replied 16 years, 8 months ago 3 Members · 5 Replies
  • Adam Taylor
    January 7, 2010 at 9:38 am
    Hi Malcolm (why is your name so familiar?) – you might try a little application i found on the web a while ago called “What Size” – this will search your entire hard drive and list everything (including hidden files) and show you how big the files are.
    It is really useful for tracking down large files or finding why your hard drive is suddenly full. Be careful how you use it as it quite easy to delete a file without knowing exactly what it is.
    Its possible that your render was so big that you ran out disc space before the render completed.
    I think that may be the case here because you say the media is on an external drive, yet its used up loads of laptop disc space. It has probably rendered a huge cache of data but run out of space and not finished the process..therefore using up space but not showing the final movie.
    Out of interest – what format are you rendering, and how long is the finished edit?
    Digital Heaven have a free downloadable dashboard widget that will tell you how much disc space is needed for various formats/codecs based on running times…could be a useful thing to have. Bear in mind you will need more disc space than is shown, simply because discs use free space to shuffle data during read/write operations
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
  • Malcolm Brabant
    January 7, 2010 at 9:49 am
    Hi Adam
    I am a BBC one man band correspondent, perhaps that’s why the name is familiar.
    I also have a youtube site called Brabantfeatures.
    Thanks for the assistance I will now go and dig.
    I am exporting a sequence as a film. It’s about 70 minutes long.
    And I am bewildered.
    I will get back to you.
    My email is malcolm.brabant@gmail.com
    best
    Malcolm
  • Paul Dickin
    January 7, 2010 at 10:32 am
    Hi
    I have had experience of a ‘disappearing’ movie export, when using a stranger’s Mac.
    I could ‘see’ that the exported movie existed – it was there in the list if I reopened the FCP Export dialogue box – visible in the file-structure view of the dialogue box. But I couldn’t retrieve the movie from the Finder – it was effectively invisible.
    I put this down to an OS X User/permissions and as it wasn’t my computer to fiddle with I just used the workaround of saving my movie again to my own FW drive which had no permissions issues.
  • Malcolm Brabant
    January 7, 2010 at 10:49 am
    Thank Paul and Adam,
    I have resolved the issue by buying whatsize.
    The file was buried in volumes in a folder with the name of the external hard drive.
    The mystery to me is why finder and sherlock failed to find the film with the correct name.
    And Adam, Whatsize was a real whizz.
    Thanks again.
    I do have one more question.
    I normally shoot in 4×3 on a panasonic dvx 100.
    For my son’s school play I shot on anamorphic 16x 9 so I could coordinate my footage with another shooter.
    I have managed to create the project and film on 16 and 9.
    But when I try to re-export it to the camera to put it on tape, I find that it is coming out squeezed, despite adjusting the settings on teh camera to (either letter box or squeeze)
    Any suggestions?
  • Adam Taylor
    January 10, 2010 at 11:35 pm
    ahh yes, of course…BBC news correspondent – thats where i have heard your name. Used to be an ITV regional news vt editor myself – glad i’m out of that game now!
    Ok – question – is the timeline you edited on set to anamorphic? From memory as i’m not in front of fcp right now, its four or five down in the Sequence menu. If not, then click the anamorphic checkbox.
    I’m a little puzzled when you said the format you output was a “film”. I was asking what file format / codec you are using to edit and playout the material. That can often have a bearing on the kind of problems you may be having.
    regards
    Adam
    Adam Taylor
    Oldham, UK
