Activity Forums Apple Final Cut Pro Legacy lost easy setups
  • lost easy setups
    Posted by K Hendrickson on April 16, 2007 at 9:12 pm
    I’m using FCP 5.1.4 on a Power PC quad 2.5, and whenever I trash my FCP preferences, I lose the easy setups I’ve created. They’re still in my custom settings folder, but they don’t show up in my easy setups list. What’s causing this, and is there a way of calling them up again without having to re-create them?
    Kris
    Andy Mees replied 19 years, 5 months ago 5 Members · 4 Replies
  • Thaxter Clavemarlton
    April 16, 2007 at 10:11 pm
    You need to be using a utlity that will “trash” your peferences, but save all of your custom settings.
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    or
    https://pistolerapost2.com/fcprescue/
  • 13 Create COW Profile Image
    13
    April 17, 2007 at 1:14 am
    Its because those custom settings are stored in your preference files.
    Like the last person said use FCP Rescue it creates a backup of your good preference files that it uses to replace the ones that have gone bad.
  • Jeremy Garchow
    April 17, 2007 at 2:49 am
    When you bring up the easy setup window (control-q) make sure to hit the little show all checkbox.
    Jeremy
  • Andy Mees
    April 17, 2007 at 3:09 am
    you might even want to go one step futher and use FCP Attic from https://www.chesa.com/pro/
    does the same as FCP Rescue, but lets you also back up custom keyboards, button bars, window layouts etc plus you can choose your backup location (in order to more easily facilitate migrating your settings between machines)
