Activity Forums Apple Final Cut Pro Legacy Lost Digital Cinema Desktop twin-screen options
  • Lost Digital Cinema Desktop twin-screen options
    Posted by Rod Main on May 18, 2008 at 12:30 pm
    Since I installed Kona LHe on my MacPro system running FCS2, I have lost the twin monitor options in the “View” pulldown for “Digital Cinema Desktop” under “Video playback”. I am now only offered “Main” and “Fullscreen”, “Raw” and “Actual size” have disappeared.
    Any suggestions??
    Thanks in advance
    Rod Main replied 18 years, 3 months ago 2 Members · 4 Replies
  • Lee Adair
    May 28, 2008 at 10:17 pm
    Same problem here. Just did a clean install of Leopard and FCS2, ran updates and started editing, and I’ve got the same issue. The options were available with the same hardware configuration under OS 1.4.X and my previous Kona LHe driver.
    MediaWorks, Inc.
    Your Image is Our Mission; ‘On Target’ is Our Mantra; Satisfaction is Our Manifesto
  • Rod Main
    May 29, 2008 at 7:32 am
    The problem cleared up immediately for me when I downloaded and installed the latest Kona driver (5.1) from the AJA website. Hope this helps for you.
    Good luck
    Rod
  • Lee Adair
    May 29, 2008 at 3:07 pm
    Did you download the “NDD” version or the other one? I got the other one, which might be my problem.
    Lee
    MediaWorks, Inc.
  • Rod Main
    May 29, 2008 at 8:29 pm
    The other one. Good luck
    Rod
