Activity Forums Storage & Archiving Lost connectivity to storage device
  • Lost connectivity to storage device
    Posted by Edwards Willeam on November 11, 2009 at 11:11 pm
    The event indicates a loss in connectivity to the specified storage
    device. The path indicated is the last path that went down.
    Example
    The following is an example of an error for this type of event:
    Lost connectivity to storage device naa.
    60a9800043346534645a433967325334. Path vmhba35:C1:T0:L7 is down.
    Affected datastores: “Storage1” Impact
    Any virtual machines using the affected datastore may become
    unresponsive.
    If the service console root file system is on the affected datastore,
    then the service console becomes no responsive and you cannot manage
    your ESX host.
    Edwards
    Irrani Dam replied 16 years, 9 months ago 3 Members · 4 Replies
  • Jordan Woods
    November 12, 2009 at 1:03 am
    so you lost connection to the storage that sits behind your vmware host? is that what I’m understanding here? what storage do you have? Maybe I’m out of the loop on this one, but I think it would be good to have a bit more information.
    -jw
  • Irrani Dam
    November 13, 2009 at 12:09 am
    Hello,
    The storage device reading (vmhba35:C1:T0:L7) mentioned in the
    example
    earlier contains several potential failure points:
    • vmhba35 – HBA (Host Bus Adapter)
    • C1 – Channel
    • T0 – Target (Storage processor port)
    • L7 – LUN (Logical Unit Number or Disk Unit)
    To determine the actual failure or to eliminate possible issues:
    1. Identify the available storage paths to the reported storage
    device
    by running the esxcfg-mpath -l command
    2. Check that a rescan does not restore visibility to the targets.
    3. Determine whether the connectivity issue is with the iSCSI storage
    or the fiber storage. Perform one of the following depending on what
    your connectivity issue is:
    o To troubleshoot the connectivity to the iSCSI storage using the
    software initiator:
    a. Check whether a ping to the storage array fails from ESX.
    b. Check whether a vmkping to each network portal of the the storage
    array fails.
    c. Check that the initiator is registered on the array. Contact your
    storage vendor for instructions on this procedure.
    d. Check that the following physical hardware is correctly
    functioning:
    ? Ethernet switch
    ? Ethernet cables between the switch and the ESX host
    ? Ethernet cables between the switch and the storage array
    o To troubleshoot the connectivity to the fiber attached storage,
    check the following:
    a. The fiber switch zoning configuration permits the ESX host to see
    the storage array. Consult your switch vendor if you require
    assistance.
    b. The fiber switch propagates RSCN messages to the ESX hosts
    4. Check the physical hardware for the following:
    o The storage processors on the array.
    o The fiber switch and the Gigabit Interface Converter (GBIC) units
    in
    the switch.
    o The fiber cables between the fiber switch and the array.
    o The array itself.
    Important: A rescan is required after any change is made to see if
    the
    targets are detected.
    kind regards,
    Irrani
  • Edwards Willeam
    November 13, 2009 at 12:19 am
    We have stonefly’s opti SAN.Physically verified the all connections.checked the path also all things are perfect.
  • Irrani Dam
    November 14, 2009 at 12:48 am
    I guess it is caused by ESX multipathing. If ESX has issue to connect to one target portal and it happens to use round-robin load balance policy, you will see this error. Any virtual machines using the affected datastore may become unresponsive. However, since there are still path to the lun, VMs are not affected. You can check load balance policy on ESX and use Fixed policy. This will make it active/passive. If you have multiple LUNs, you can force ESX to use different active path for each LUN.
