Activity › Forums › Apple Final Cut Pro Legacy › Lost audio on import of video
  • Lost audio on import of video
    Posted by Jim Reed on November 22, 2009 at 9:56 pm
    I’m very new to FCP. I ran a 4 hour video through Mpeg Streamclip and converted it to an mpeg. The audio was converted at the same time. I have the video on a disk and it plays fine with good audio. However, when I imported it in to FCP, the video came in, but know audio.
    1. Any idea what I did wrong.
    2. I had to render the mpeg in FCP before it could be viewed in FCP. Is this common or should I use a different extension instead of mpeg.
    Thanks for the help.
    Jim Reed replied 16 years, 10 months ago 2 Members · 2 Replies
  • Nicole Haddock
    November 23, 2009 at 3:34 am
    FCP doesn’t work with MPEGs, as you’ve seen. Next time convert the file to a Quicktime using MPEG Streamclip or your converter of choice and you should have audio.
  • Jim Reed
    November 23, 2009 at 1:41 pm
    In Stream Clip, there is a function; Export to Quicktime. Is this the one I should use? I’m use to using AVI or MPeg in Adobe, I can see this is going to change.
    Thanks for the reply.
