Activity Forums Apple Final Cut Pro Legacy Lossy compression
  • Lossy compression
    Posted by Simon Cawthorne on December 9, 2005 at 2:17 pm
    Hi All,
    I’m putting together a workflow for a project and will be capturing with a Targa Cinewave card & codec to edit in FCP 3 and compositing in AE, all of which I’m used to doing and am on top of (mostly, anyway!)
    I wish to lay off masters to digibeta at a facility house this time so that I can do a nominal on-line and sound dub. It’s not for broadcast, but the client wants to see/visit a facility house. Now, the facility house has suggested I render my final export out as an Avid Meridian codec, which I’m OK with in principle. However, capturing with a Targa Cinewave codec, then rendering to an Avid code makes me nervous that there will be a loss of quality as the files are rendered into an entirely different codec.
    In this case I hope to go
    IN: TARGA CODEC,
    FCP EDIT: TARGA CODEC (so no re-render),
    “EXPORT” from FCP: Linked FCP videos, which can be picked up by AE without re-rendering.
    AE: compositing/effects
    EXPORT/RENDER from AE: AVID CODEC, carry to facility house on FW drive.
    layoff to digibeta master from the facility house AVID after basic conform to standards.
    So, basically – only one change of codec throughout. I don’t know the AVID codec and what options it it has, as I’ve never had reason to deal with it directly before, but any advice on whether there is likely to be a problematic loss of quality would be appreciated.
    regards
    doogal
    Simon Cawthorne replied 20 years, 9 months ago 3 Members · 3 Replies
  • Todd Beabout
    December 9, 2005 at 5:29 pm
    Avid has 1:1 “uncompressed” (8-bit) on it’s Meridian line, so you should be fine. However, I’m not sure how you would [doogal] “EXPORT/RENDER from AE: AVID CODEC, carry to facility house on FW drive.” I’m sure this can probably be done, I’ve just never done it, and I must not have the proper codec loaded. If you do have that codec, then it should work out. I’d do a test on a short clip and send it to them to make sure everything imports properly, and looks good.
    -Todd Beabout
    Vazda Studios
  • Bryce Whiteside
    December 10, 2005 at 6:41 pm
    This is unconfirmed but the Avid Meridian codec is broken in QT7 from some of the posts I have read.
    You may want to do a post search.
    FYI,
    Bryce Whiteside
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
  • Simon Cawthorne
    December 14, 2005 at 3:39 pm
    Thanks for the advice –
    In fact, I had at this early stage assumed that the avid codec would sit OK with an After Effects Render, and from what Bryce says, this aspect is something I now need to get sorted before committing to any workflow.
    However – in theory it currently looks feasible, which is a start.
    With thanks
    doogal
